Old 08-15-2012, 09:35 AM   #1
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Question Is it possible to BLOCK a Transmission Fault Code P0740 from triggering the SES lamp?
I still get the Torque Converter Clutch Too Much Slip Fault P0740 triggering my SES (Service Engine Soon) Lamp.
Before I would get the SES about once a week or 50 - 100 miles of driving. I always clear the code using the PASoft.
Car is driving perfectly fine on the code-my MPGs are the same and I don't sense any usual shifting or slippage in the transmission that comes with the code P0740.
Since May-June I rarely get the SES code and it comes up once in a month of driving (around 500 - 1,000 miles).
My car still has less than 78,000 miles and I don't plan on replacing the Torque Convertor until (or if) I have to replace the entire Transmission since the Torque Convertor Clutch labor comes out to be the same as replacing the entire Transmission.
I also read replacing just the Torque Convertor don't always clear the p0740 code or it brings up other Transmission codes like the dreaded p0741.
So is there a way to block the p0740 from setting off the SES lamp? Even if the code pops up?
delmarco is offline   Reply With Quote
Old 08-18-2012, 02:55 PM   #2
delmarco
weekend bump...
Old 08-18-2012, 03:10 PM   #3
jasonbimmer
My Ride: 2001 BMW 330xi
TCC issue could be either valve body solenoid issue or the actual clutch. it does not affect drivability but as for codes there is nothing you can do.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 08-18-2012, 03:18 PM   #4
delmarco
Thank You!
