E46 Convertible
Old 08-15-2012, 05:15 PM   #1
mcarou5
My Ride: 2000 BMW 323Ci
Coolant light on
Has anyone had the coolant light turn on?
mcarou5 is offline   Reply With Quote
Old 08-15-2012, 05:24 PM   #2
mcarou5
Light turns off and then comes back and I checked the coolant level and its ok but I cant figure out why is this happening.
Old 08-15-2012, 05:39 PM   #3
sakumaxp
My Ride: 02 M3 convertible
just add some coolant, and see if it persists...
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 08-15-2012, 05:54 PM   #4
mcarou5
it has coolant I have checked
Old 08-15-2012, 11:33 PM   #5
MyNewRag
My Ride: 05 ///M Convertible
Maybe it is scared because you are taking pictures while driving over 70 MPH...
But seriously, what does your gauge read? Is your aux fan running when the light is on? Have you checked your thermostat? Cap have a good seal?
MyNewRag is offline   Reply With Quote
Old 08-16-2012, 02:43 AM   #6
monkeyjuice5150
My Ride: ///M3 droptop
Send a message via AIM to monkeyjuice5150
Light will keep coming back.
You need to bleed the system when adding coolant to turn off the light.
There's a black plastic + screw next to the cap. Or near around it. Fill the coolant when engine is cold to recommended level. Close it back up. Start the car. Let the car warm up. Start unscrewing the black screw slightly till hot air and coolant start spilling out. When there's nothing left to spill out. Close the screw. Turn off the car. Let the car cool down again. Fill to recommend level again.
This get rid of all the air bubbles inside the coolant system which is causing the light to come on.
monkeyjuice5150 is offline   Reply With Quote
Old 08-16-2012, 08:27 AM   #7
mcarou5
thanks monkey juice ill try it and post back
