Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Old 08-16-2012, 06:06 PM   #41
jdstrickland
My Ride: '94 325iC & '00 323i
Originally Posted by xavi330i View Post
I run cold pressed virgin coconut oil.
Cold pressed virgins are more fun if you warm them up first.
Old 08-16-2012, 06:59 PM   #42
mikhit
My Ride: 2003 325xi
With just over 100k miles, I burn a quart every 2500 miles or so. No leaks. VCG, OFHG and CCV all replaced around 90k miles.
mikhit is offline   Reply With Quote
Old 08-16-2012, 07:05 PM   #43
Suseer
My Ride: Cayman S
After having my oil pan gasket replaced earlier this year, haven't noticed it go down at all.
Suseer is offline   Reply With Quote
Old 08-16-2012, 08:34 PM   #44
cbritton
My Ride: 2000 323i
2000 323i with 184k. No oil consumption.
cbritton is offline   Reply With Quote
Old 08-16-2012, 08:45 PM   #45
blksab65
My Ride: 323i Touring
So the question is why do some of our cars burn while others don't
blksab65 is offline   Reply With Quote
Old 08-16-2012, 09:05 PM   #46
IxNay
My Ride: 2000 328Ci 5sp SP
Some of them leak oil, others burn oil, others do both, and others don't do either.
IxNay is offline   Reply With Quote
Old 08-16-2012, 09:54 PM   #47
sprintman
My Ride: Ex 325CI owner
Originally Posted by RKiepper View Post
This will start a war
I use Castrol Full Synthetic 5w-30
Unless you mean the OEM BMW 5W30 made by Castrol then the one you're using doesn't meet spec (too thin, HTHS to low).
sprintman is offline   Reply With Quote
Old 08-16-2012, 10:18 PM   #48
TerryTouring
My Ride: 2002 325xiTouring
80,000 miles, uses half a quart in 3, 500 miles, although I suspect that most of this is leaking.
TerryTouring is offline   Reply With Quote
Old 08-16-2012, 11:02 PM   #49
RKiepper
My Ride: 1999 E46 328I x2
I switched from 10w30.. Get better performance from the 5.
RKiepper is offline   Reply With Quote
Old 08-17-2012, 01:21 AM   #50
e46dub
My Ride: 2000 328i
150k and doesn't burn a drop
e46dub is offline   Reply With Quote
Old 08-17-2012, 03:51 AM   #51
DualZ
My Ride: E46 330ci
Send a message via AIM to DualZ
No oil burning here !
DualZ is offline   Reply With Quote
Old 08-17-2012, 04:22 AM   #52
sprintman
Neither meet spec. Why do people do this?
Old 08-17-2012, 04:40 AM   #53
DHK
My Ride: 2002 BMW 325Ci
The m54 engine is not all that different from the e36 six beaters that took anywhere from 5w30 to 20w50 without any trouble and most of them are still on the road.
Most of the work BMW has done with oil recently has been to stretch the amount of time between oil changes.
In reality if you use a semi synthetic 5w30 and changed it ever 4k miles or so you probably wouldn't be hurting much. The genius of the BMW Long Life stuff is that you can go 15k between oil changes without issue.
Im not saying I would do it, but it probably isn't going to kill your car.
DHK is offline   Reply With Quote
Old 08-17-2012, 05:15 AM   #54
Skchamaa11
My Ride: 2001 BMW 330ci
Mine burns oil when I drive it hard and I run very lightweight oil
Whether you win by a inch or a mile winning is winning
Skchamaa11 is offline   Reply With Quote
Old 08-17-2012, 05:15 AM   #55
Skchamaa11
That might be the reason too
Old 08-17-2012, 05:38 AM   #56
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I drive my car pretty hard so it burns about a quart every 6k or so
Old 08-17-2012, 08:37 AM   #57
sprintman
Totally incorrect. The spec means it's a 30W that's closer to a 40W in viscosity when most are at the low end of the SAE scale and closer to a 20W. It also means HTHS meets or exceeds 3.5 when the majority of XW30's are below 3.0, and so on. Typical comment from somebody who doesn't understand oil!
Old 08-17-2012, 10:29 AM   #58
Stinger9
My Ride: '04 330Ci
would have been nice if your rebuttal was understandable
then we'd all understand oil
Old 08-17-2012, 12:04 PM   #59
RKiepper
I switched to 5w30 for engine noise issues, it flows better then what the previous owners used.
And I originally bought my oil from the dealer, until I figured out what the rebranded 5w30 was.
Old 08-17-2012, 03:29 PM   #60
Jay146992
My Ride: E90 335i & E46 M3
My car has 272k miles and burns 1qt every 500 miles. No leaks. OFHG, VCG and oil pan gasket replaced at 220k. CCV replaced at 225k miles and made no improvement. My car has always used oil but it got a lot worse after 150k miles.
07 335i - Eisenmann Exhaust, JB4, M-Tech Body Kit, 19" TSW Nurburgring Wheels.
06 M3 Vert- Stock
Jay146992 is offline   Reply With Quote
