Old 08-16-2012, 04:41 PM   #1
BB BMW
My Ride: 04 330ci ZHP
Car MD diagnostic tool
Has anyone used this diagnostic tool on their BMW?
or is this just another TV add gimic tool that does not do what it says it will?
It comes with diagnostic tool, software, connection cable, etc.
Just checking to see if anyone has tried it.
https://shop.carmd.com/ps_a6/?gclid=...FQP0nAod6REAJA
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
Thomas Jefferson
BB BMW is offline   Reply With Quote
Old 08-16-2012, 04:58 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You can get the same thing for free by just asking at any autozone for a free code reading...I believe they do that everywhere but in California...and you're not there as I recall.
There is some software that seems to come from questionable sources...mailed from abroad and then you download a full software program. This is only $30 and gives you something of value. But again, in reading on it, it sounds like the software, although freely available, is nonetheless pirated. Look into that. If I'm right and if you have ethics, then this might not be the best choice for you.
Autozone is the way to go...or just get a Peake scanner...or some $30 obdII code reader from a local autoparts store.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 08-17-2012, 02:54 PM   #3
2003silver330i
My Ride: 03 BMW 330i
Just hard to believe that this scanner would tell me exactly what caused all 6 of my ignition coils to fail at the same time when clearly there is some other underlying issue causing them to all misfire.
2003silver330i is offline   Reply With Quote
Old 08-17-2012, 04:51 PM   #4
Guest021715
Account closed.
Checking for a loose coil pack ground wire and searching for vacuum leaks would be a start.
There is no way all 6 of them failed, as you've already realized. Even a faulty MAF could give you these problems.
Old 08-17-2012, 05:04 PM   #5
2003silver330i
I logged and cleared the codes to see if they will come back.
