Old 08-16-2012, 04:58 PM   #1
eas
Past Site Sponsor
My Ride: BMW
eas | Inspection I/II, VANOS Maintenance, Subframe Reinforcements, and More!
As your preferred SoCal BMW shop, EAS is proud to offer service for your M3! We can offer various services for your car, from maintenance, to parts installation, and even dyno sessions. Our large facility is complete with a full service lift, specialty tools and equipment, and two highly skilled technicians with over 20 years of combined BMW experience. We know how much your BMW means to you, which is why we treat every car with the utmost care and respect. Our customers always let us know how valuable it is for them to have a shop that they can trust with their BMW.
For your e46 M3, we are offering Oil Change Services, Inspection I, Inspection II (including Valve Adjustments), Subframe Reinforcements, and VANOS maintenance:
Inspection I: $825
- Oil Change Service
- Differential Fluid Change
- Transmission Fluid Change
- Clean MAF Sensor
- Cabin Air Filter Replacement
- Fuel System Cleaning (Redline Fuel System Clearer)
- Valve Adjustment ( Can be done separately as well)
- Full Inspection of the Vehicle (Check for leaks, fluids, pressures, bushings, brakes, etc.)
- Reset Service Indicator
- Road test with check of brakes, clutch, steering, suspension).
Inspection II: $1225
- Engine Oil Change (BMW/Castrol TWS 10w-60, BMW OEM Oil Filter)
- Check engine/transmission for leaks.
- Check rear axle for leaks.
- Visually check fuel tank, lines, and connections for leaks.
- Check condition, position, and mounting of exhaust system. Examine for leaks.
- Check power steering system for leaks.
- Check overall thickness of front and rear disc brake pads.
- Examine brake disc surfaces.
- Clean brake pad contact points in calipers.
- Grease wheel center hubs.
- Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage.
- Check front control arm bushing for wear.
- Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
- Check for free movement of the parking brake cables.
- Check tire pressures
- Check condition of tires
- Check brake pads
- Half-shafts; check for leaks at flexible boots.
- Inspect entire body according to terms of rust prevention limited warranty.
- Valve Adjustment
- Cabin Filter Replacement
- Check engine cooling system/heater hose connections for leaks.
- Check coolant level and antifreeze protection level; add coolant if necessary.
- Check level of brake and clutch fluid in reservoir; add fluid if required.
- Reset Service Indicator.
- Replace spark plugs.
- Replace intake air cleaner element.
- Check battery
- Check instrument panel and dashboard illumination.
- Check all warning/indicator lights, check control.
- Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
- Check wiper and washer system(s); wiper blades, washer jet positions.
- Check condition and function of safety belts.
*All OEM BMW Fluids and Parts used unless otherwise noted or requested
Other Services offered for your e46 M3:
- Belt Replacement: $180
- Constant Pressure Valve Replacement: $125
- Chain Tensioner Seal: $110
- Oil Change Service: $150
- Powerflex or Rogue Engineering Rear Trailing Arm Bushings: $ 225(with Powerflex)
- Powerflex or Rogue Engineering Front Control Arm Bushings: $275(with Powerflex)
- Subframe Reinforcement: $1250 (If subframe is already damaged, repair may be required at an additional cost.)
- VANOS Maintenance (Vanos Seal, Vanos Filter and O Rings): $150
Give us a call today to set up your appointment to get service done!
eas is offline   Reply With Quote
Old 09-05-2012, 02:55 PM   #2
eas
Past Site Sponsor
My Ride: BMW
Call eas now to make an appointment to get your Inspection II done!
Old 09-19-2012, 06:17 PM   #3
eas
Past Site Sponsor
My Ride: BMW
Call eas to schedule an appointment for Inspection I, Inspection II, Subframe Reinforcements and other services
Old 10-31-2012, 01:31 PM   #4
eas
Past Site Sponsor
My Ride: BMW
Call in to schedule your appointment!
Old 11-14-2012, 04:04 PM   #5
eas
Past Site Sponsor
My Ride: BMW
Schedule your service at eas now!
Old 06-05-2013, 02:52 PM   #6
eas
Past Site Sponsor
My Ride: BMW
Set up an appointment to get your E46 M3 Serviced at eas!
