Old 08-16-2012, 05:46 PM   #1
Apple4life
Apple4life's Avatar
My Ride: 03 325i SULEV
Ordered new window regulator, how should I make the window stay up temporarily?
Passenger side window decided to fail today.
What's the best way to temporarily and securely hold the window glass up?
No tree branch please
Apple4life is offline   Reply With Quote
Old 08-16-2012, 05:59 PM   #2
2003silver330i
My Ride: 03 BMW 330i
Remove the door panel and push up the regulator by hand. If the wire is wrapped around the motor then remove the motor, unwrap the wire and then push the regulator up by hand. Reinstall motor.
2003silver330i is offline   Reply With Quote
Old 08-16-2012, 06:20 PM   #3
adaseb
My Ride: 2002 BMW 320i
Search for a thread on here where someone put a piece of 1" wood inside the panel to hold it up. Try searching for "rear sedan zip tie" or something like that. I would search it for you but I'm on my phone.
Don't tape it up. People will break in
adaseb is offline   Reply With Quote
Old 08-16-2012, 06:21 PM   #4
adaseb
Didn't know you already had the regulator. Ignore my last post
Old 08-16-2012, 06:59 PM   #5
Apple4life
Apple4life's Avatar
I just ordered it today. It will probably get here on Monday. So I need something to hold up the window in the meantime
Old 08-16-2012, 07:19 PM   #6
eneka
My Ride: 2003 325i
I just taped mine with some clear tape...
eneka is offline   Reply With Quote
Old 08-16-2012, 07:46 PM   #7
Lemonsqr
My Ride: 2001 TiAg 330i
stick or piece o wood would work
Lemonsqr is offline   Reply With Quote
Old 08-16-2012, 07:52 PM   #8
jdstrickland
My Ride: '94 325iC & '00 323i
Tape. Clean the tape residue off with WD40 when the time comes.
Old 08-16-2012, 08:55 PM   #9
Apple4life
Apple4life's Avatar
I used some clear tape. Hopefully this will keep the glass up
Thanks guys!
Old 08-16-2012, 08:55 PM   #10
BimmersGarage
My Ride: E46 330i
Never mind... my suggestion below.
I didn't realize you removed your door panel already.
3M doubleside tape and a quarter inch piece/strip of debit card.
Move your glass up to position and doubleside tape the strip to the bottom edge of window, this will hold the glass up til you are ready to DIY.
NOTE: I hope you have your battery disconnected.. Do Not drive your vehicle with the door panel/sensors unmounted, it may set off your door airbag or cause an airbag light warning. Just a heads up.
BimmersGarage is offline   Reply With Quote
Old 08-16-2012, 08:58 PM   #11
///MPR77
My Ride: 02 ///M3 Tri-Ped
You can use a small piece of cardboard as a shim placed at the bottom and wedged in towards the pillar.
Old 08-17-2012, 01:28 AM   #12
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
If it's a sedan or wagon, which has a frame around the window, the clear tape works great. Don't use duct tape, blue painters tape or any other tape that is obvious or someone will take a picture of your ghetto car and post it in a Honda forum. If it's a 2-dr then it becomes a lot more difficult.
I think all of us here know that the BMW windows regulators suck, but, they also suck on my wife's Toyota Camry. She had both front window regulators fail within a week of each other at around 70k miles. To keep the window up I took the door panel off and used a couple of C-clamps to hold the window in the closed position.
scottjoh is offline   Reply With Quote
Old 08-17-2012, 07:26 AM   #13
SpoonerDee
My Ride: 2005 E46
Mine failed too recently. But I caught it just before it broke completely and was able to close the window one last time. Replacing it this weekend. Been broken for a month now
Just haven't had the time.
But on my last car (e36) I used clear tape.
SpoonerDee is offline   Reply With Quote
Old 08-17-2012, 07:58 AM   #14
xavi330i
My Ride: 2004 330i smg
Blue painters tape. A couple strips and you are good to go.
xavi330i is offline   Reply With Quote
