Old 08-16-2012, 09:05 PM   #1
kblounge
My Ride: 325i, '01
Funny idling while coasting and stopping
Ok, so I apologize ifthishasbeenaddressed a thousand times.ButI think it is slightly a different problem. So I just swapped out my voltage regulator and since then when I'm driving down the road and push in the clutch, the RPM's will drop down to nearly 0 bounce up to just above 500,and then fluctuate between the two until it gradually settles at about 250-300. In putting things back together could I have messed with something to cause this? Ant help/suggestions would be greatlyappreciated!
kblounge is offline   Reply With Quote
coasting, idle, pulley, rough idle, vanos
