Old 08-17-2012, 11:35 AM   #1
Redryan98
My Ride: 07 Legacy GT 5MT
Alignment done, I'm told seized camber bolt
Hello. I had an alignment done recently and was told by the shop that the camber adjustment bolt for one of the rears was seized and couldn't adjust it. I'd like to get under there and see what I can do, and buy replacement if needed.
I assume its part of the "Rear Axle Support/Wheel Suspension" area. Can someone confirm which bolt it is or point me in the right direction? Thanks!
http://realoem.com/bmw/showparts.do?...40&hg=33&fg=30
Redryan98 is offline   Reply With Quote
Old 08-17-2012, 11:39 AM   #2
cposk
My Ride: 08' E90 M3
#10. It is an eccentric bolt that is turned to adjust camber. It is very easy to get to with the wheel off.
Photobucket
cposk is offline   Reply With Quote
Old 08-17-2012, 11:40 AM   #3
xavi330i
My Ride: 2004 330i smg
PB blaster that SOB.
xavi330i is offline   Reply With Quote
Old 08-17-2012, 11:44 AM   #4
doggy
My Ride: 330ise
the bolt in the pic cposk has taken is the one at the bottom
doggy is offline   Reply With Quote
Old 08-17-2012, 11:46 AM   #5
xavi330i
Originally Posted by doggy View Post
the bolt cposk has taken a picture of is the strut bolt but it is #10 on realoem
Don't know about you, but I'm looking at the control arm eccentric bolt, and not the shock bolt.
Old 08-17-2012, 11:47 AM   #6
xavi330i
Nice ninja edit
Old 08-17-2012, 11:52 AM   #7
Redryan98
wow, that was quick. Thanks for the help fellas!
Old 08-17-2012, 12:01 PM   #8
Redryan98
That's the plan. I'll probably pull the wheel off and soak it a few times, let is sit overnight, soak it some more and go from there.
Old 08-17-2012, 12:30 PM   #9
doggy
My Ride: 330ise
haha! that pic so f in large on my laptop, takes 2 pages to see whole thing
OP its 18mm on both sides so you need 2 spanners/ratchets. Mine was so rusted i used a 19mm, lucky i didnt round it
Old 08-17-2012, 01:03 PM   #10
cposk
My Ride: 08' E90 M3
Ha, big pictures are the way to go! I have a 24 inch monitor so I never noticed an issue...
Luckily, if you end up stripping/rounding it, the location makes it very easy to cut it with an angle grinder.
Old 08-17-2012, 02:00 PM   #11
Redryan98
thanks for your help guys. The camber wasn't off by too much but I'm OCD and don't like seeing red on the alignment printout.
