Old 08-17-2012, 01:39 PM   #1
328ci5sp
My Ride: 2000 BMW 328ci 5MT
Gauges go down when I turn on headlights!
This happened to me twice already but when I turned on my head lights my gauges (RPM, gas, engine temp) goes down for a second as if the car was off and then goes back on but the car stays on. I did a D2S xenon conversion using D2S adapters and a capacitor for the ballast but not sure if that has anything to do with my problem.
328ci5sp is offline   Reply With Quote
Old 08-17-2012, 02:03 PM   #2
Alex323Ci
My Ride: M3 & 323Ci (sold)
That is usually a bad ground in the cluster somewhere or in your case a big voltage draw. yes it sounds like your xenon conversion.
Old 08-17-2012, 02:13 PM   #3
xavi330i
My Ride: 2004 330i smg
Is it wired up correctly with the ballast on its own current draw circuit?.
xavi330i is offline   Reply With Quote
Old 08-17-2012, 02:27 PM   #4
328ci5sp
Think a hid relay might help?
Old 08-17-2012, 02:27 PM   #5
328ci5sp
Yes. Ballast and resistors are installed correctly
Old 08-17-2012, 02:30 PM   #6
Alex323Ci
Yes, I think running a relay would be the first thing I'd do.
There are probably similar threads about this in the Lighting Forum of this site. If you look there you'll probably find this exact issue and fix.
