Keyfob Tester! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-17-2012, 01:01 PM   #1
jfoj
My Ride: 330CiC, M5, X5, E93
Keyfob Tester!
So I was at my local Advance Auto parts for something today and they had this keyfob tester just below the check out register where the small keyfob batteries were located.
I took out my BMW and GM keyfobs and tried them out on the keyfob tester and it worked quite well. The LED flickered indicating the keyfob was functional and I was actually able to get some distance from the tester and it continued to pick up the keyfob as I pushed the buttons.
This would be helpful to make sure you keyfob and/or keyfob buttons are working before you try to cut a perfectly good keyfob open!
You might check and see if any of your local auto parts or hardware stores have one of these testers at the battery display.
Old 08-17-2012, 01:10 PM   #2
xavi330i
My Ride: 2004 330i smg
Am I a geek because I test my keyfob with a spectrum analyzer here at work?
xavi330i is offline   Reply With Quote
Old 08-17-2012, 01:12 PM   #3
lsteg
My Ride: 2001 330ci
Great find!
lsteg is offline   Reply With Quote
Old 08-17-2012, 01:13 PM   #4
jfoj
Not everyone has a $50k spec analyzer sitting around to play with.
Next time I am there, I will check my garage door opener to see if it detects that!
