Old 08-25-2012, 07:38 PM   #61
fanatic128
My Ride: 2005 330i
Originally Posted by Solidjake View Post
Wooden block + hammer to the tip of the rotor = win
Thank you sir. That did the trick
fanatic128 is offline   Reply With Quote
Old 08-25-2012, 08:04 PM   #62
choxor
My Ride: JDM
Remember when you're putting things together that a little anti size is your friend.
Old 08-25-2012, 08:17 PM   #63
fanatic128
My Ride: 2005 330i
Yep, put anti-seize. Im all done . Car stops so much smoother. I like the choice in rotors and pads I made thanks to recommendations.
Old 08-25-2012, 08:18 PM   #64
Alex323Ci
My Ride: M3 & 323Ci (sold)
Originally Posted by fanatic128 View Post
Yep, put anti-seize. Im all done . Car stops so much smoother. I like the choice in rotors and pads I made.
Don't forget to "bed" them in correctly.
Old 08-25-2012, 08:31 PM   #65
fanatic128
My Ride: 2005 330i
what's proper way to bed axxis pads?
Old 08-25-2012, 08:36 PM   #66
Stinger9
My Ride: '04 330Ci
Not really necessary if you follow the BMW manual and go easy on your new brakes for the first 300 miles.
From my manual:
Brake system
Approx. 300 miles/500 km must elapse
before the brake pads and rotors
achieve the optimal pad-surface and
wear patterns required for trouble-free
operation and an extended service life
later on.
To break in the separate parking brake
drums, apply the parking brake lightly
when coasting to a standstill - at a traffic
signal, for instance - provided that
traffic conditions allow you to do so.
To avoid corrosion, repeat this procedure
from time to time.
Want all your questions answered? Go to: http://www.stoptech.com/technical-su...l-white-papers
And read up on all the brake knowledge you need from the source of accurate info.
Among other things, this: http://www.stoptech.com/technical-su...l-white-papers
is here.
Old 08-25-2012, 08:50 PM   #67
Trashcan
My Ride: 2002 330ci
Bookmark
Trashcan is offline   Reply With Quote
Old 08-25-2012, 09:00 PM   #68
fanatic128
My Ride: 2005 330i
Old 08-25-2012, 09:45 PM   #69
Alex323Ci
http://www.stoptech.com/technical-su...-system-bed-in
