Old 08-17-2012, 10:06 PM   #1
Destephicon
My Ride: 2001 BMW 320I
Help! Whistling Sound?
Hi there,
For the past month now I've been getting a strange whistling/squealing sound from the interior of my car. The whistling/squealing noise sounds like it is coming from my steering wheel area. Sometimes, when I turn on my car, the strange whistling/squealing sounds comes on, and sometimes while I'm driving, the whistling/squealing sound comes on. It weird. I tried to fix it by replacing all of my tensioners, pulleys and belts but, the whistling/squealing sound still occurs. Could it be the Power Steering Pump? If anyone could give me advice or can help me out, that will be awesome. Thanks in advance.
Destephicon
Destephicon is offline   Reply With Quote
Old 08-18-2012, 07:04 AM   #2
RayPooley
My Ride: 320i SE Coupe
Sure its not behind the dash? I had a air con fan on a E36 did that once. I think a leaf found its way in there. Fiddled with the knobs a bit and went away. Having said that I also had a mouse behind my dash once. Didn't squeak but started to stink after a while!!!!
Old 08-18-2012, 07:49 AM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Does it sound like this? If so replace the ecu box fan
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 08-18-2012, 11:32 AM   #4
Destephicon
Hey Solidjake, it does sound similar to that noise in the video. I will replace the ECU Fan and let you know if that fixed the problem. Thanks
Destephicon
