///M3 Forum
Old 08-17-2012, 09:19 PM   #1
Aioros_M_class
My Ride: 04 M3
M3 e46 wont start
hello guys here is the thing when i was leaving to do some shores with my car when i was about to started it i heard a loud click in front of the engine, well since then i thought it might be the starter engine but it works very good, then i checked the fuses in the glovebox and the one in the engine bay but neither of this things that i checked seems to solves my problems, i dont know if the key is the problem because when the ignition is on the fuel pump works can you help me dealing with this problem
Aioros_M_class is offline   Reply With Quote
Old 08-17-2012, 09:25 PM   #2
llcoolj0n
My Ride: M3
Only a click? try tapping the key a few then try to start it. See if that works!
llcoolj0n is offline   Reply With Quote
Old 08-17-2012, 09:31 PM   #3
Aioros_M_class
My Ride: 04 M3
already did and nothing
Old 08-17-2012, 09:56 PM   #4
LSM3
My Ride: E46 ///M3
Put your interior light on and turn the key again. If it dims, then its your battery - get a new one.
___________________________________________
2006 CS M3 | ESS Tune : CSL SMG tune : Eisenmann Race : Eibach : Tekarbon
LSM3 is offline   Reply With Quote
Old 08-17-2012, 10:00 PM   #5
Aioros_M_class
My Ride: 04 M3
I already checked that the battery is brand new I bought it like a month ago and I also tested so the voltage is good, the fuel pump is also working, but when I put the key in the ignition position nothing happens the only thing I hear is the fuel pump working besides that nothing happens
Old 08-18-2012, 09:57 AM   #6
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
my problem was a clutch sensor when there was no click or sign of the starter. Ive also one time one the m3 had a bad BST cable.
But narrow it down until you have the starter to replace.
"I hated cutting suckers with my razor blade. But everyday it's a struggle to get major paid. Anyway
it's so hard on a Jigga in this city, no pity..And ain't no love for the scrubs that be buying dimes.. If you could walk a mile in my shoes.."
MachRc is offline   Reply With Quote
Old 08-22-2012, 03:15 PM   #7
Aioros_M_class
My Ride: 04 M3
ok guys here is the following things that i have done:
Fuel pump working
Battery is new
Fuses checked and working
starter motor working
the only two things left to test ews and the clutch switch
Old 08-22-2012, 09:36 PM   #8
$ilent ///M
My Ride: 03.5 M3 smg lsb
How did you verify the starter motor is good.
$ilent ///M is offline   Reply With Quote
Old 08-23-2012, 11:40 AM   #9
Aioros_M_class
My Ride: 04 M3
well I took out the starter motor and tested it with the battery
Old 08-23-2012, 08:36 PM   #10
MachRc
E46Fanatic
MachRc's Avatar
If its not the things you listed and the clutch switch was bypassed what else can it be? So strange. I never hear of the ews or immobilizer problems that meds these cars up.
Old 08-23-2012, 10:24 PM   #11
Aioros_M_class
My Ride: 04 M3
and what if i have problems with my key how do i know if my keys are giving me the problem there is a way of testing it, the battery in the key only works for the remote or for the chip inside the key im running out of options here
Old 08-23-2012, 10:36 PM   #12
$ilent ///M
is it a crank no start problem when you try to start do you here anything from the starter?
Old 08-23-2012, 10:47 PM   #13
Aioros_M_class
My Ride: 04 M3
the starter doesn't even engage the only thing i can hear is the fuel pump working nothing else, i dont know if the key maybe the problem because i only have one key
Old 08-23-2012, 10:56 PM   #14
$ilent ///M
did you check the fuses and relays behind the glove box
Old 08-23-2012, 11:00 PM   #15
Aioros_M_class
My Ride: 04 M3
yeap all of that has been checked battery, bst, fuses, relays, fuel pump, fuses close to the ecu, starter motor
Old 08-23-2012, 11:02 PM   #16
$ilent ///M
i heard a lot of the threads saying the ignition switch fails often
Old 08-23-2012, 11:08 PM   #17
Aioros_M_class
My Ride: 04 M3
i dont think is the ignition switch because when i put the key in ignition i can hear the fuel pump working
Old 08-24-2012, 08:34 AM   #18
$ilent ///M
have you tried checking signal/connections to the starter (voltage drop test)
Old 08-24-2012, 02:40 PM   #19
tmiked
My Ride: 04 M3
Its the starter.
They fail in one specific position. If you remove it, it will work.
tmiked is offline   Reply With Quote
Old 08-24-2012, 04:12 PM   #20
MaddHatter00
My Ride: 04 M3
Mine did the same thing. It would start in the morning, I would drive it to temp then it wouldn't start again till it cooled off. I replaced the starter and has been perfect ever since. Get a new starter. And problem should be solved.
MaddHatter00 is offline   Reply With Quote
m3 e46 wont start starter
