///M3 Forum
Old 09-02-2012, 10:20 AM   #21
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
how are you Aioros! Been worried!
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 09-02-2012, 10:36 AM   #22
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Go back to the battery, OP...even though it's new and even though you have the voltage you want to see, that doesn't mean you have the amperage to start your car. It could test fine out of the car, but you know, it's not really pushing anything out of the car...no load on it.
Try jump starting your car...if it starts, then drive for 20-30 mins. on highway. Keep the donor car revving a little and keep them hooked up for 5 mins. or so. Also, double check that your starter cable/connections are good (particularly under the + terminal under hood).
Also, do check that bst...check that battery cables are tight...wiggle them and pull up on them...we've had many cases of that issue happening.
If you've been making a lot of short trips and no long ones, that's why the battery could be new but otherwise drained.
Eliminate battery for sure before moving onto other things.
Clutch switch also, as has been mentioned. Do you have a clutch stop? Remove it.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-01-2012, 11:36 AM   #23
KHUT46M3
My Ride: 2003 e46 M3
Ugh, same problem on my 03. Tapped on the starter nothing. Fuses all ok. I read a thread that said re-sync your key. I bought the car and only got one key so I don't want to cut it open to try to even attempt to replace the battery. How would I check the clutch switch to see if that is my problem??? Not replacing my starter as a last resort if nothing works any new insight would be greatly appreciated
KHUT46M3 is offline   Reply With Quote
Old 10-01-2012, 01:08 PM   #24
Aioros_M_class
My Ride: 04 M3
well my problem was the ews so i changed that and did a resync between the ews and the dme and presto that was it, try scan it so you could see the real problem any doubts pm
Aioros_M_class is offline   Reply With Quote
m3 e46 wont start starter
