Lights - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-17-2012, 11:29 PM   #1
Coolie Jessie
My Ride: 325xi
Lights
Ive had my car for a few months now and have been trying to figure out this out..
Car: 2003 325xi sedan
The issue is when I start the car or just turn the key to the on position, the headlights come on(drl I assume) but the rear lights on the truck lid also light up and they are extra bright ( like rear fog lamps)
Any thoughts???
TIA
Coolie Jessie is offline   Reply With Quote
Old 08-17-2012, 11:55 PM   #2
EverydayGetaway
My Ride: 2003 330i ZHP
Are you referring to your reverse lights? That sounds like a pretty serious issue... can you take a picture to clarify?
EverydayGetaway is offline   Reply With Quote
Old 08-18-2012, 02:58 AM   #3
eneka
My Ride: 2003 325i
drl are the high beams on low power...is that what you're seeing?
Have you checked your taillight grounds, they might be the culprit.
eneka is offline   Reply With Quote
Old 08-18-2012, 06:55 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
+1 on checking the rear grounds and any corrosion on the bulb holder.
Old 08-18-2012, 08:53 AM   #5
Coolie Jessie
My Ride: 325xi
The lights that turn on up front are not the high beams (the outer lights turn on) headlights
Yes the light below the reverse lights, they are the ones that are on..
So again get in the car turn the key to the on position headlights and lights in the trunk turn on.
No corrosion on the bulbs or bulb tray. Will get pics or a short vid up asap
Old 08-18-2012, 10:25 AM   #6
LD330XI
My Ride: '09 335i
That almost sounds like the ribbon cable for your LCM face is bad. IIRC if you ground the 4th wire in from the left, the rear frogs activate. It may be the same for the headlights just a different wire.
LD330XI is offline   Reply With Quote
Old 08-18-2012, 02:01 PM   #7
Coolie Jessie
My Ride: 325xi
I tried a euro lcm with rear fog button... Samething tried swapping faces Samething
If I can't get a solution from some1 here it's bye bye 3series... The sad part is I do like the car but this light issue is turning me off
