Old 03-14-2009, 06:15 PM   #1
brodaiga
My Ride: 330ci
peake code: pedal position sensor 1
The sensor is on the gas pedal, not throttle body. Replace the gas pedal? Anybody get this before?
brodaiga is offline   Reply With Quote
Old 05-11-2009, 10:45 AM   #2
1980e12mpl
My Ride: slowthrees
I have the same code....did you get this sorted out? anyone?
1980e12mpl is offline   Reply With Quote
Old 05-11-2009, 12:36 PM   #3
tony325ci_51
My Ride: BMW 335i 2007 Coupe
Have seen this code once, though only when doing routine code checking, it didn't throw a fault light.
Gas pedal has 2 (drive by wire) sensors built into the pedal module. It can work quite happily with one, it seems to have 2 just as a backup.
If one is faulty it does mean that you're running with no backup though so if the 2nd ever goes faulty you could be stranded.
Solution is to replace pedal module, they're not too expensive new.
There are usually cheap ones around on ebay as well:
http://cgi.ebay.co.uk/BMW-M3-E46-Acc...03112001r15296
tony325ci_51 is offline   Reply With Quote
Old 05-11-2009, 02:50 PM   #4
brodaiga
My Ride: 330ci
I never replaced, but sometimes get a strange issue that I think may by due to this code. Sometimes, I am pushing it, and when around 3500rpm it quickly goes to 65,00rpm when the car not getting any more power, as if the clutch was engaged in neutral and I was revving it from 3500 to 6500. It happens a couple times a week. I wondering if fixing the gas pedal would fix that
Old 05-11-2009, 03:41 PM   #5
Arsevader
My Ride: '90 325i, '02 325it
That sounds like a slipping clutch problem not a gas pedal problem.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 05-11-2009, 03:59 PM   #6
brodaiga
My Ride: 330ci
yes, but it does not happen when I engage the clutch. It may happen in the middle of acceleration.
Old 05-11-2009, 11:33 PM   #7
Arsevader
Exactly. Sounds to me like your clutch is slipping. That's the only reason for the revs to increase that quickly without acceleration forward.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Old 08-18-2012, 03:37 PM   #8
Jersey Swags
My Ride: 330i
Bringing this one back from the dead. This problem is kicking my ass. Threw a new pedal assembly at it, no go. SES back on. Pedal sensor 1 AND 2. Any ideas? I'm going to set this 01 330i on fire. I head that this code can be thermostat related. WTF? Please help.
01 330i 207whp/204wtq
06 CBR Fireblade
97 GSXR 600
Jersey Swags is offline   Reply With Quote
