Old 08-18-2012, 10:06 PM   #1
Melcheeley
My Ride: 95 325i, 00 328i
S in gear indicator
What does it mean when there is a S in the gear indicator display and the car won't start?
Melcheeley is offline   Reply With Quote
Old 08-18-2012, 10:10 PM   #2
wannasupra
My Ride: 2006 Hayabusa
"S"ucks to be you
wannasupra is offline   Reply With Quote
Old 08-18-2012, 10:12 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
Originally Posted by wannasupra View Post
"S"ucks to be you
Your car can't be in "Drive" when you try to start it. Only Park and Neutral. You have it in sport mode, a subset of "Drive," which is probably why it won't start.
Old 08-18-2012, 10:16 PM   #4
Bemwe_03i
My Ride: 2003.5 E46 M3 smg IR
silly trying to start car in drive
Bemwe_03i is offline   Reply With Quote
Old 08-18-2012, 11:30 PM   #5
Melcheeley
It's not in drive. I have a non steph gm5. My fuse 30 was blown. Replaced that but still have the "s".
Old 08-18-2012, 11:38 PM   #6
bschillberg710
My Ride: 2002 BMW 325i
Perhaps somethings gone wrong with the shifter and it thinks it's in sport mode?
bschillberg710 is offline   Reply With Quote
Old 08-19-2012, 12:50 AM   #7
jasonbimmer
My Ride: 2001 BMW 330xi
the switch stuck? I remember the non-step had a mode switch.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 08-19-2012, 01:42 AM   #8
wannasupra
So is it in park or neutral when you try to start it?
Old 08-19-2012, 03:31 AM   #9
Melcheeley
Yes.
Old 08-19-2012, 09:43 AM   #10
45auto
My Ride: 2006 330CIC
Does the display in the gear indicator change when you move the shift lever between park, neutral, and drive?
45auto is offline   Reply With Quote
Old 09-07-2013, 02:58 PM   #11
TH1BMW
My Ride: 323Ci Convertible
The issue is the oil sensor. It will blow Fuse #30 (7.5 amp) and stay in S. Replace the fuse and oil sensor and you are good to go.
TH1BMW is offline   Reply With Quote
