///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 08-19-2012, 03:38 PM   #1
Thekingarthur
My Ride: 2002 M3 SMG Vert
Refinishing the SMG shift knob - DIY
Since the shift knob on my SMG M3 vert was in awful condition, and not being a fan of chrome anyway, I decided to refinish it to match the silver trim. Replacement knobs are pricey ~$90, and other options can cost even more. So while I save up for a brushed aluminum knob, I think this mod works pretty well. It definitely looks and feels a lot better. Here's a before and after picture:
To start remove the knob by pulling hard, careful not to injure yourself or your car, and then disassemble it. The leather trim pieces can be removed with a screwdriver and the plastic insert pops out with an exacto blade. You can then scrape out the double sided tape and remove the screw.
The shift boot plate pops right out by lifting up on it. The shift boot and trim ring both snap into the plate, as well at the SMG switch. The glue holding the trim ring plastic "hex nuts" and the chrome SMG lettering is easily removed with pliers.
The next step is to sand down the chrome surface for better adhesion of Bondo, and completely remove it in areas that it is peeling. It would be ideal to remove all traces of the chrome surface, but that proved to be very difficult. The problem is the chrome is actually a thin layer of metal so it takes an enormous amount of sanding to remove. It will not peel off areas that it isn't already peeling and when sanding begins to reveal the plastic underneath, it is very easy to remove large chunks of plastic when aggressively sanding the metal surface. So take your time with this step. The image below you can see where I melted the plastic in a ring around the center when sanding too fast. (I had the knob mounted on a Dremel tool which rotated WAY too fast. Moved it to a battery powered drill and that worked great.)
After you prep the surface, add your layers of Bondo. Applying Bondo to the entire surface rather than in patches where needed works better for the same reason as the sanding problem above. If you only apply it where it's needed, then when you sand it down to shape you will also remove material from the section that has no Bondo or not enough. So just apply a bit more Bondo than you think you should and sand away until your fingers bleed. Mounting the knob on a drill made sanding it to a perfect round shape very easy. For the SMG plate, be sure to apply Bondo to the underside and not just the top to fill the holes. That will prevent the filled holes from simply popping out.
After sanding to a smooth surface with finer and finer sandpaper, then it's time to paint. I painted the SMG plate black to match the majority of the interior plastic trim, altnating between a matte black paint and satin paint then finishing with 1500 grit light sanding. The knob and trim ring were painted silver with a polished clear coat on top. As with painting ANYTHING, multiple thin layers of paint with drying time in between is the best way to do it. Yes it takes a long time, but the quality is worth it. After finishing the silver paint and wet sanding it smooth add your layers of clear coat. Again, thin layers are the key to building up a solid paint job without drips and runs. After the clear coat, wet sand until it is completely smooth then buff and polish it.
Finally reassemble the SMG plate and glue the leather trim pieces back on the knob and put it all back in your car.
Thekingarthur is offline   Reply With Quote
Old 08-19-2012, 04:06 PM   #2
Active 2
My Ride: 02 E46 m3
not sure if its my computer, but the pictures are not working
02 ///M3 Jet Balck/ Imola
AA Headers | AA Exhaust | AA tune | Ground Control | AFE scoops | Apex EC-7
Active 2 is offline   Reply With Quote
Old 08-19-2012, 04:14 PM   #3
Thekingarthur
Yeah I'm trying to figure that out as well. Not sure what's going on. I've verified the links twice now. I can load them up in a browser separately just fine.
Old 08-19-2012, 04:18 PM   #4
ImSoFreaknWhite
My Ride: '06 M3 SMG VERT
Send a message via ICQ to ImSoFreaknWhite Send a message via AIM to ImSoFreaknWhite Send a message via Yahoo to ImSoFreaknWhite
I really want to do this, please fix the pics!!
Jordan
My Build Thread
l Status Gruppe One-Piece Lip l Anodized CCW Classics w/ Polished Lips l Black Grills/Gills & Emblems l Carbon Fiber Roundels
Status Rear Section l K&N 57 Series CA Intake l OEM JB Hardtop l TM Drilled/Slotted Rotors l D2 Coilovers w/Camber Plates l VIS CSL VERT Trunk
ImSoFreaknWhite is offline   Reply With Quote
Old 08-19-2012, 04:28 PM   #5
Thekingarthur
Ah, it's forbidden on the server to direct link. Let me play with some settings on my website...
Old 08-19-2012, 04:34 PM   #6
Thekingarthur
Ok, fixed the images.
Old 08-20-2012, 08:19 AM   #7
KashM3
My Ride: ///M
Great write-up. Thanks for giving me a little "after work" project.
S14.NET O.G. S54 E30 ///M3
Mike Rad boosted avus e36
AW E46 ///M SMG
Still on the hunt for a low mileage 997 GT3.2 !Herro Rennlist....
KashM3 is offline   Reply With Quote
Old 08-20-2012, 09:31 AM   #8
Thekingarthur
No problem.
Old 08-20-2012, 01:02 PM   #9
JamaicanBlueE46M3
My Ride: E46 M3
Nice job, If u don't mind me asking, what is that red thing by the tray above the shift knob?
JamaicanBlueE46M3 is offline   Reply With Quote
Old 08-20-2012, 02:02 PM   #10
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
It's the little things that really make a difference. What wouldn't necessarily seem like a big project still makes a world of difference, I think it looks great, nice job!
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 08-20-2012, 02:06 PM   #11
ChrisRedmon
My Ride: 2002 PY ///M3
Dude, that looks great!
2002 Phoenix Yellow E46 M3 l 6MT l Nappa l Nav l STG Coilovers 7k/8k l BMW Performance SSK l OEM ZCP's l Kirk Roll Bar l Motorsport Hardware l Besian Systems l CSL/GTR Carbon Fiber Hood, Trunk & Diffuser l Status Gruppe Sec. 3 l Custom Rear Brace l Rear Seat Delete l Coby Wheel Products
ChrisRedmon is offline   Reply With Quote
Old 08-20-2012, 02:37 PM   #12
Thekingarthur
That's the display for my Whistler Pro 3600 Radar/Laser Detector. I customized the ash tray for that install. Working on a write up for that too, possibly a video as well.
Old 08-20-2012, 02:42 PM   #13
Thekingarthur
Indeed. After general maintenance I wanted to start modding the stuff that makes the most difference first, the things I interact with and use the most. stereo, shift knob, radar detector, and steering wheel next.
Old 08-20-2012, 05:00 PM   #14
illestminimike
My Ride: Project Drama
This is going to come in handy. Thanks.
Old 08-20-2012, 09:31 PM   #15
serdar255
My Ride: '01 325ci / '90 325i
Good work looks awesome
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 08-20-2012, 11:31 PM   #16
choxor
My Ride: JDM
Good painting skills. Definitely looks tons better.
Old 08-21-2012, 12:00 AM   #17
Thekingarthur
Thanks guys! I used to airbrush a lot so I have a bit of practice spraying paint around.
Old 09-30-2013, 12:48 PM   #18
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Hey still any way we can get these pictures up? I went to pry the leather inserts out and it seemed like they were breaking
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 09-30-2013, 02:46 PM   #19
Brianthechemist
My Ride: E46 M3, E60 530i,
gentle heat gun action will loosen the PSA that holds them on.
Brianthechemist is offline   Reply With Quote
Old 09-30-2013, 04:09 PM   #20
CarbonZHP
CarbonZHP's Avatar
Re: Refinishing the SMG shift knob - DIY
Alright will do. And I did pry the top logo off. Just painted black under and it went back perfectly
Sent from my HTC6500LVW using BimmerApp mobile app
Modification Thread
m3, refinish, shift knob, smg
