Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 08-19-2012, 04:54 PM   #1
Fitment
My Ride: 2002 M3
Lightbulb *** E46 M3 Alternator DIY ***
So since i was on a little budget this month due to school.
Tools needed:
* Allen Key
* Torx 50
* Small Philips Screw Driver
* Flat Head Screw Driver
* Ratchet
* Socket # 10, 16, 17.
* Extension
* Towel
1. Disconnect the positive terminal from your battery
2. Start taking off your OEM/Aftermarket Intake scoop & filter and cover so you have enough room to take off the Alternator.
There is 4 clips thats holding the scoop
4. Intake scoop is off.
5. Take off the side plastic pieces that's attached to the fan cover. There is two clips on each side that gets this loose. This will help you get more room at the end when you are going to pull the alternator off.
6. Take the cap off so you can get access to the long bolt that is holding the alternator down. I simply used a little Philips screw driver to pop it off and bingo you will see the bolt. Its a 16mm bolt if you have a breaker bar your life will be much easier compared to a regular ratchet.
Cap off
7. Below the alternator drive, there is a tensioner to get the belt loose. It has a black cap/cover just like the alternator.
8. Once you took the cap off the tensioner uses a Torx key size 50 i attached it to my ratchet and pressed down on it just the way i tighten a regular bolt. This will get the belt loose gently slide the belt out from the alternator drive.
9. Now you can take the long bolt out that holds down the top portion of the alternator.
10. Take the bottom bolt that is holding the alternator as well.
11. Use an Allen key to remove the hard oil lines make sure you put a towel underneath the oil lines so you don't get oil on the alt. It will be just a little oil but i still ended up covering the alternator.
12. Oil lines removed
13. Disconnect the negative wire from the alternator. Its held by a metal clip i simply took it off with a flat head and it just came off.
14. Disconnect the positive cable from the alternator. Its a 17mm socket see the pictures below.
15. After you disconnected the cables. You can start taking off the alternator by moving it back and fort depending on how old your alternator is mine was pretty easy to take out.
If i missed something feel free to fix my mistake.
-Thanks.
LSB /// Nappa Black.
Fitment is offline   Reply With Quote
Old 08-19-2012, 05:15 PM   #2
agent050
My Ride: 2005 M3
Ha! This is a sweet DIY. I will bookmark this. Thanks!
agent050 is offline   Reply With Quote
Old 08-20-2012, 03:25 AM   #3
bufu-m3
My Ride: 01 M3
You just saved my $300 in labor at the shop. Thank you so much.
bufu-m3 is offline   Reply With Quote
Old 08-20-2012, 08:40 AM   #4
cak323i
My Ride: ///M3 & 330i ZHP
What was the size of the allen key?
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 08-20-2012, 09:51 AM   #5
ZkansasZ
My Ride: a horse
Kudos on the DIY
You don't have to remove that oil line if you have small hand/fingers
When reinstall, make sure the little notch on the pulley bolt fit into that small slot there up top.
but ya, it's straight forward process.
02AccordV6(sold) 03350zMT(sold) 04E46///M3MT(sold) 06RSXauto 07G35auto
ZkansasZ is offline   Reply With Quote
Old 08-20-2012, 12:48 PM   #6
jhaurimn
My Ride: 01' 330ci
Haven't had to touch the alternator on my m3 but I took it out multiple times from my 330.
be patient getting it out, it takes a little wiggling. I would personally take the whole fan shroud off to make room to work. Would imagine it would be tricky getting the alternator out otherwise .
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 08-20-2012, 01:11 PM   #7
Custom3
My Ride: HellRot 330CI
wow first post and its a awesome DIY. And here I thought this forum was dying. Thanks for keeping the E46 community alive!
Old 08-23-2012, 10:32 PM   #8
dr1v3n
My Ride: M3, F250
good instructions, I have replaced mine before, I did not remove the oil lines. Seriously thought, screw bmw for putting such a shitty alternator in the car
dr1v3n is offline   Reply With Quote
Old 08-25-2012, 08:02 PM   #9
DJ Syxx
My Ride: BMW M3
Good DIY mate.
DJ Syxx is offline   Reply With Quote
Old 08-26-2012, 02:02 AM   #10
skeeterv
My Ride: e46
great DIY. Might be doing mine in a while... BTW did your alternator go bad or was it preventive? Also miles on the unit?
skeeterv is offline   Reply With Quote
Old 08-26-2012, 01:44 PM   #11
Fitment
My Ride: 2002 M3
Hey,
Yes mine went out at 57k miles. I had the battery light lit up on the cluster.
Old 08-28-2012, 01:22 PM   #12
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
Excellent thread!
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 08-30-2012, 01:14 AM   #13
Teslazerok
My Ride: 2003 M3 6SPD
Well done, the only discrepancy I have is that you don't have to remove the oil lines. The only issue they cause is getting to the back of the alternator for the connections and the really aren't too hard to get around. I don't have small hands and managed just fine to get in there to disconnect the negative connection by hand. The positive has enough slack to get the alternator out before undoing it.
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 11-01-2012, 11:15 PM   #14
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
nice write up, thanks!
i'd just like to mention that when removing the negative clip, you push down on it and that releases the plug. there's no need to remove the clip itself. it's similar to the plug you remove when changing the oil filter on the m3
JetBlackE46 is offline   Reply With Quote
Old 11-04-2012, 06:03 AM   #15
rossi0112
My Ride: Black 328 CI
Done this on my car 156kmiles done as I was getting a flashing battery light on the dash, read up some stuff and forum members were pointing at the Voltage regulator on the alternator. In the end I bought a new alternator at a cost of £154 with a £30 refund when I return my old unit.
Anyway I used the op to help me out taking the alternator out except for I didn't have to remove everything mentioned only the fan housing for better access and the air scoop and air filter, I then got easy access to the Alt. Took me no time at all about 30 mins in total. I also took the benefit of fitting new belts as the serpentine belt was cracked all the way round, so good job really.
Just to confirm on my model 2000 328CI I had the Torx 50 bolts in the tensioners as some have mentioned an Allen head bolt in there..also the serpentine belt tensioner was stiffer than the AC one so watch the Torx Head socket doesn't come out as you could easily damage the radiator matrix, so take your time on that one..The AC tensioner was easy..
Thanks for OP for starting this thread..the E46 forum comes to assistance again..thanks.
2000 Black 328 CI (mine)
2002 Blue 325I M Sport (wife's)
2000 Yamaha YZF R1 (mine)
2008 Skyjet SJ125-23 (sons)
2009 Kinroad XT50-18 (sons)
rossi0112 is offline   Reply With Quote
Old 04-07-2013, 09:42 PM   #16
Bimmerboye46
My Ride: 01 325i Sport
I have an 01 325i.
I noticed this tube on the under-aft side of my alternator, it looks loose. Is this tube supposed to fit onto the alternator snug with a metal clamp or is this it? Any advice helps! Thanks
Bimmerboye46 is offline   Reply With Quote
Old 06-04-2014, 03:02 AM   #17
TopazCoop
My Ride: '06 M3
Just wanted to say thanks. Tensioner on my 06 M3 cab was an 8mm hex, oil lines were removed with a 6mm hex (be careful with the o-rings!). This is another good reference thread.
Valeo out at 47k, Bosch reman from AutohausAZ in. Cross your fingers I don't have to do this again any time soon. Royal pita.
PS don't do this when it is 108F.
TopazCoop is offline   Reply With Quote
Old 10-06-2014, 01:07 AM   #18
Guram1993
My Ride: 325ci
OP, if you just get the nut on cable loose (useing a ranch wrench) , and than take out the alternator bolts (ones that mount on the motor), and than remove the cable completely, will this help to avoid takeing off the oil line ? im planning this for my car soon, id rather not disconnect the oil line if i dont have to. thanks in advance.
Guram1993 is offline   Reply With Quote
Old 03-05-2015, 02:55 PM   #19
LemansM
My Ride: lemans blue ///M3
Send a message via AIM to LemansM
Which to buy?
So what brand is everyone using for an alternator these days?
2002 e39 ///M5 - Lemans Blue
2003 e46 ///M3 - Lemans Blue Individual
LemansM is offline   Reply With Quote
Old 05-07-2015, 10:47 AM   #20
RyanPR
My Ride: E46 M3 vert
FYI: My car (2003 M3) was NOT a T50, it was a hex 8mm.
RyanPR is offline   Reply With Quote
alternator, diy, e46, m3, replacement
