Old 08-19-2012, 08:33 PM   #1
GotVANOS?
My Ride: 2003 325xi Touring
Differential bearing
While replacing the front driverís side CV axle I noticed that the bearing that the axel rides on in the differential is totally frozen and will not move at all. currently itís acting as a bushing, but Iím afraid that after a while it will start producing metal fragments, get into the diff and raise hell. Does anyone have an idea how to replace this bearing? It looks like a MAJOR project
Shes not your average grocery getter. This 2.5L of fury doesnt mess around.
E21<E30>E36>E46>E90>F30
5TFUUU, If one more person tells me to sell my car and buy an ///M Im going to light their family on fire and make them watch.
*****BUY MY 330XI AUTO TRANS AND PARTS. CHEAP!!!******
GotVANOS? is offline   Reply With Quote
Old 08-19-2012, 09:27 PM   #2
JEFFEFECKS
My Ride: 05 IB ZCP
Send a message via AIM to JEFFEFECKS
Originally Posted by GotVANOS? View Post
While replacing the front driver's side CV axle I noticed that the bearing that the axel rides on in the differential is totally frozen and will not move at all. currently it's acting as a bushing, but I'm afraid that after a while it will start producing metal fragments, get into the diff and raise hell. Does anyone have an idea how to replace this bearing? It looks like a MAJOR project
Actually It's not that difficult. Just time consuming & pretty inexpensive as well if of course you DIY.
1. Drain fluid
2. Remove Diff cover
3. Remove Axles from the diff completely
4. You should be able to take the carrier out after doing the prev. steps
5. Take Carrier & new bearings to a Machine shop to have the old bearings removed and install the new ones.
6. Re install & add new fluid
That was just a quick explanation.
New bearings are about $~20, Install of new bearings $~30, New diff fluid ~$130 (ECS Tuning)
You prob would want to buy new seals as well. Now if you were to have a shop all do this for you then you would most likely get R4PED.
'05 IB ZCP AA Stg 2
JEFFEFECKS is offline   Reply With Quote
Old 08-19-2012, 09:34 PM   #3
GotVANOS?
yeah, but I have that whole pice of **** XI subframe to contend with. I have to basically drop the whole subframe wich is a PITA
bearing, cv axle, differential, xi
