2001 330ci, odd shutting off issue - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-21-2012, 06:50 AM   #1
220k330
My Ride: 2001 330ci ZSP
hey gang, so on my 01 330ci, 5 speed --- 205k on it, she runs great -- no mods etc, everything up to date - only thing I know is bad is the oil level sensor, anyway, on the way to work this morning, 4th gear, about 40 mph she shuts down -- dead, then starts right back up like nothing happened. happened twice more before I got to work. The clock does reset is the only odd thing. I have not had a chance to scan for codes.
thoughts? it sounds bad (control module of some sort)
ideas?
many thanks
Geoff
220k330 is offline   Reply With Quote
Old 08-21-2012, 07:19 AM   #2
lsteg
My Ride: 2001 330ci
I would go and get the codes read. That sounds like the easiest way to troubleshoot this issue.
lsteg is offline   Reply With Quote
Old 08-21-2012, 07:28 AM   #3
220k330
Yea....no codes...only thing I can find is a little standing water in the battery box....
Old 08-21-2012, 07:34 AM   #4
lsteg
My Ride: 2001 330ci
Please tell me you cleaned it up?
Old 08-21-2012, 07:36 AM   #5
220k330
Well yea I'm going to but I don't think that would explain what happened. The terminals are tight and clean
Old 08-23-2012, 07:16 AM   #6
220k330
Well I had more than a little water in the battery box....I had gallons of water in the battery box...water was getting in through the tail light seals I put in...so fixed those drained it and cleaned it...and it has been fine!!!
Old 08-23-2012, 07:43 AM   #7
lsteg
My Ride: 2001 330ci
and you doubted me
Old 08-23-2012, 11:53 AM   #8
220k330
You figure the water was shorting out the battery somehow?
Old 08-23-2012, 11:55 AM   #9
lsteg
My Ride: 2001 330ci
Most likely the water would cause the battery to short or cause a power surge and for safety the car would shut off.
Kind of shooting in the dark but it sounds good....right?
Old 08-23-2012, 12:03 PM   #10
kaldE46
My Ride: 2001 325i
I had water in my battery area as well. Not sure if the problem started when I got my EE Led tails. Need to make sure it's not happening again.
kaldE46 is offline   Reply With Quote
