Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.60 average. Display Modes
Old 08-21-2012, 04:11 PM   #1
Jeff321
My Ride: Bmw 328 ise (e46)
Angry Just got ripped off with a 330 D, engine noisy :( please help, may need a new engine
hi guys yesterday i have aquired a 2003 e46 330d m sport 132k, car looks amazing, however upon purchasing i never realised the engine was so tappety and noisy, the car had been warmed up maximum, drove it back around 100miles and everything seemed fine, got home left it switched off for a few hours and started it from cold and the engine sounds really loud like a tappety noise, theres no warning lights on the dash and the car drives fine however it is seriously seriously annoying and ashameful when driving it down the road, i am considering having it repaired, however if it is out of my budget then ill consider taking it to auction on saturday , the car looks amazing and i would love to keep it however when purchasing i didnt really want to spend anything on a car and baught it considering it would last me a few months at least when i id saved up some cash to tweak it up,
now im not sure what path to take i left it at a bmw specialist near by and he couldnt figure out what the noise is and stated he had a 530d on the ramp which had the exact same problem and they were investigating it,
does anybody know any decent and affordable bmw specialists north west, im in manchester,
or even a place where i can get a replacement engine from? labour i have been quoted for fitting only is around 500
not sure which path to take guys please help all advice is always appreciated,
Jeff
Jeff321 is offline   Reply With Quote
Old 08-21-2012, 04:22 PM   #2
dpower2012
My Ride: 05 BMW 325CiC
Vanos? If it's the cause, it's not too pricey of a fix. Just takes some time I hear. Pardon the pun...
Upload a video of the sound and the guru's on here will tell you what you need.
dpower2012 is offline   Reply With Quote
Old 08-21-2012, 04:38 PM   #3
Jeff321
Hi thanks for your reply, will upload a vid tomorrow, just to clarify its a diesel, does the 330 diesel have vanos?
Old 08-21-2012, 05:01 PM   #4
dpower2012
Sorry I guess I should have noted the "D" in your 330d description. I don't think the diesels have a vanos.
Old 08-21-2012, 05:06 PM   #5
NE1L
My Ride: 320Cd M-Sport
Nope, the Diesels do not have the VANOS system. It could be due to running on cheapo supermarket Diesel, I know some cars sound terrible running it. Run some fuel system cleaner through the system and replace the fuel filter located under the cab below the front passenger seat.
1. REMOVE and blank off the "swirl flaps". These appear prone to breakages and the metal debris knackering the engine. This is considered an absolute must do task. http://www.pmwltd.co.uk/
2. Replace the engine crank case breather. The engine build year you have may have the old "loo roll" style that gets clogged up and can lead to premature turbo failure. Get the "Vortex" type, not expensive 32 or so.
3. Remove and clean the EGR valve and ensure it is operating smoothly. When the engine is not running it is closed and is opened up via vacuum control when the engine is running.
4. Enter the hidden menu system on the car and check the coolant temperature is actually normal. The needle on the dash will read at 12o'clock (optimum) even if the engine is running as cold as 70C. Only below 70C does it drop dramatically. There are two thermostats on the diesel engines (euro IV spec engines). One on top of the EGR cooler and the main stat is next to the water pump. The stat fitted to the EGR cooler opens in two stages, stage 1 is around 70C, full open occurs at 90C. The main water stat should open at 88-90C.
5. Have the car serviced, replace oil, oil filter and air filter.
6. Run the car on proper diesel, BP or Shell in my opinion. It does not need to be the Ultimate or V-Power stuff, just the regular diesel. Do not use supermarket crap as it does not have the advanced additives to burn cleaner and keep the engine cleaner. The Supermarket stuff meets the minimum BS EN standards, but it will soot up the internals, as you will see when you view the inside of the EGR valve.
Think I have about covered most things, best of luck with it.
Neil.
NE1L is offline   Reply With Quote
Old 08-21-2012, 05:16 PM   #6
Jeff321
Neil now thats what i call some expert advice!!!!
all sounds pretty much reassuring to try anyway, even if it doesnt resolve the issue, however it is a cheaper option than changing engines, just spoke to a guy also and he adviseed havingthe injectors tested, so will do all of the above and also get injectors tested, may well have been run on cheap diesel and stuff, there was a canister in the back with diesel in so may just be something easy to fix, not getting my hopes up but still will try these and get back to you, not sure when my next day off is but will keep u updated, please keep the comments coming all advise is great
thanks
Old 08-21-2012, 05:23 PM   #7
NE1L
Jeff, it is worth while bookmarking the following sites:
www.realoem.com
http://tis.spaghetticoder.org/
http://forum.e46fanatics.com/showthr...=320965&page=1
http://www.bimmerdiy.com/dir/e46
http://m3.madrussian.net/
www.bmwland.co.uk
Also have the glow plugs tested, while you are at.
Neil.
Old 08-21-2012, 09:25 PM   #8
drivesacrj
My Ride: 2000 323i
Diesels ARE tappety....thats the noise they make, even brand new. No amount of servicing will make your engine as quiet as a petrol engine. I've been sitting at a stop light with a new gen diesel x5 in the left lane and I could hear it's motor....with my windows up.
drivesacrj is offline   Reply With Quote
Old 08-21-2012, 09:36 PM   #9
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
This...
Old 08-21-2012, 10:00 PM   #10
adaseb
My Ride: 2002 BMW 320i
You do realize diesels all sound like crap.
They all go chugga chugga chugga
adaseb is offline   Reply With Quote
Old 08-21-2012, 10:13 PM   #11
jasonbimmer
My Ride: 2001 BMW 330xi
diesels are always very knocking (thats how it works).
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 08-22-2012, 04:43 AM   #12
Jeff321
yes they generally are quite noisy however u can tell a healthy engine to a not so healthy one, ive previously owned a few 320d's which were allot quiter and the engine didnt knock, this sounds like a piston slap, or bottom end bearings, or even tappets.....
Old 08-22-2012, 05:44 AM   #13
sabreuk
My Ride: 323ci vert
id have a look at the injectors they do get clogged and when an injector is off in a diesel or not spraying right they do sound like tractors. i would get a screwdriver with a wooden handle and place the tip of the screwdriver on the end of the injectors whilst it is running and you should hear clicking and they should all sound the same. if you get a pinging or one sounds different from the others thats your problem. get some injector cleaner down it and see if it cleans it up. if not then maybe new injector.
failing that on diesels the pump timing might be slightly off which would cause a rattly engine its a common thing on diesels here the uk for that to happen if it is just needs timing set again and the noise will go.
failing that you might need to readjust your rockers as there maybe some wear in there and blocked by gunge if it hasnt had reagular oil changes. could be clogged a lil bit and causing the knocking noise.
i very much doubt you will need a new engine just a lil bit of tlc.
UBIQUE
EVERYWHERE
sabreuk is offline   Reply With Quote
Old 08-22-2012, 07:36 AM   #14
Jeff321
hi thanks for your replies guys, will try and get a video uploaded tonight of the sound..... hope you all know what it is.
Jeff
Old 08-22-2012, 12:26 PM   #15
Jeff321
click on the image to view video...
Old 08-22-2012, 12:34 PM   #16
tcphoto
My Ride: E92 335 MT Coupe
The phrase, "ripped off" is a powerful statement. What did your PPI say about the engine condition? If you did not have the inspection done, you are SOL because you didn't do your research. You should not throw around that phrase if you failed to do a PPI or if you have no proof that any issue was hidden by the seller.
tcphoto is offline   Reply With Quote
Old 08-22-2012, 12:51 PM   #17
DILLA
My Ride: 330i ZHP/VW Jetta
sounds like at deisel.
LRx
DILLA is offline   Reply With Quote
Old 08-22-2012, 01:00 PM   #18
kaldE46
My Ride: 2001 325i
Sounds like a normal diesel to me.
kaldE46 is offline   Reply With Quote
Old 08-22-2012, 01:05 PM   #19
sabreuk
My Ride: 323ci vert
that sounds like the exhaust is blowing to me, but the engine sounds ok. check the exhaust for leaks sounds maybe like the downpipe is blowing or the centre section of the exhaust it seems to me its the centre section blowing as its very loud by the driver door and the bonnet down. put it on ramps or jack it up and inspect for holes in the exhaust.
that knocking noise is the injectors doing there thing. thats normal.
is it sluggish on take off or accelerating?
UBIQUE
EVERYWHERE
Old 08-22-2012, 01:12 PM   #20
Merritt07
My Ride: '05 330i ZHP
+1 on this. I'm no expert on diesel engines, but to me the motor sounds fine, it sounds as though the exhaust might be the issue. I would say its definitely louder than it ought to be. My .02
My sig is bad. I feel bad.
'05 330i 6MT
Merritt07 is offline   Reply With Quote
