Old 08-22-2012, 01:28 PM   #21
gggunchi
My Ride: 2001 BMW 316i
Dude! You have a bigger problem . . . your steering wheel is on the incorrect side of the car! I'd get that looked at ASAP.
gggunchi is offline   Reply With Quote
Old 08-22-2012, 02:01 PM   #22
Jeff321
My Ride: Bmw 328 ise (e46)
doesnt anybody hear the ticking noise? ive had 320 diesels and they and all other diesels have never made that tappety noise, and tcphoto to be fair i asked the seller everything however he was in a rush to sell, and the price was definatly too good to be true, so i pressume he knew what he was selling, however its my mistake for not getting it checked, all i want to do know is just have it sorted so i can drive it , it sometimes is a little sluggish by the way guys.... i dont think the sound is very obvious in the video in person it definatly is noticeable
jeff
Jeff321 is offline   Reply With Quote
Old 08-22-2012, 02:15 PM   #23
jerseyrider
My Ride: 2001 330Ci-06 K1200s
It sounds like a diesel truck. A diesel powered BMW should NOT be that loud. You shouldn't be able to hear much of a difference from a gasoline powered BMW. I don't know what it is but it does need to be corrected.
jerseyrider is offline   Reply With Quote
Old 08-22-2012, 03:06 PM   #24
sabreuk
My Ride: 323ci vert
the lifters sound louder than they are cause the exhaust is blowing its not getting the back pressure. the ticking is the injectors which is normal. imo
UBIQUE
EVERYWHERE
sabreuk is offline   Reply With Quote
Old 08-23-2012, 02:16 AM   #25
Jeff321
it does sound like a diesel for transit lol.... ok so first point from now is to check the exhaust for leaks? if theres a leak and i sorted it would the injector or ticking noise go quiter? .. just dont know where to start with this, dont want to be spending lots of money and then also find that it isnt fixed....if id know what it is id just get it done...but due to the type of fault i just feel lost in regards to what to do
Old 08-23-2012, 02:24 AM   #26
sabreuk
My Ride: 323ci vert
if the exhaust has a leak and get it fixed it will be a lot quieter than it is. its amazing how rough an engine can sound when the exhaust is blowing. proper chelsea tractor lol. when ya check it check the manifold all the back to tailpipe.
UBIQUE
EVERYWHERE
Old 08-24-2012, 01:59 AM   #27
Jeff321
ok thanks for the reply, will try and check the exhaust tonight, also found a bmw specialist near by which i may run it buy after work today, see what he says, will keep you all updated...
Jeff
Old 08-24-2012, 07:20 AM   #28
aikmanson
My Ride: 2000 323ci
Jeff
I will also bet that you have an exhaust leak, specifically at the manifold/exhaust manifold gasket.
Your car sounds like a diesel truck, almost like a ford powerstroke. I agree with others that diesels are supposed to be loud and tappy, but this sounds like an exhaust leak fueling the issue here.
2003 Jeep Wrangler Rubicon
2000 BMW 323ci
1995 Saab 900 SE - JZW Stage 4
aikmanson is offline   Reply With Quote
Old 08-25-2012, 06:24 AM   #29
Jeff321
hi thanks for your replies, i dropped the car off to one of my local mechanics, he has checked the car and thinks the sound is coming from either the hydraulic lifters or the bottom end crank.... he said he can change the lifters for £150 labour and i would have to pay for the lifters, or he will fit an engine for £300 + engine cost.... what do u think i should do? .....
Jeff
Old 08-25-2012, 08:17 AM   #30
SpoonerDee
My Ride: 2005 E46
Jeff
You do not need a new engine. You need a new mechanic.
SpoonerDee is offline   Reply With Quote
Old 08-25-2012, 09:12 AM   #31
Chooie
My Ride: '05 e46 330i ZHP
This.
Chooie is offline   Reply With Quote
Old 08-25-2012, 10:33 AM   #32
sabreuk
My Ride: 323ci vert
agreed get another opinion there having your pants down bud.
UBIQUE
EVERYWHERE
Old 08-25-2012, 12:36 PM   #33
Jeff321
thanks for your replies guys, right so ive picked the car up and thinking of taking it to a engine rebuilding place local to myself see what they say on tuesday
will keep you all update.... youve all been really helpful thanks again.
Jeff
Old 09-11-2012, 12:53 PM   #34
RayPooley
My Ride: 320i SE Coupe
Contrary to previous comments that is a bit noisy. You got oil in the sump? What's the oil pressure like? Maybe its not getting to the top of the engine in sufficient quantity. Running a bit dry?
Old 11-10-2012, 01:18 PM   #35
dovla15
My Ride: bmw e46 318d
did you slove the problem?
dovla15 is offline   Reply With Quote
Old 11-10-2012, 03:27 PM   #36
UDM-E46 Enthusiast
My Ride: 2002 BMW 330I
Usually it's the lifters that have worn over time and get loose. Have him replace the lifters. I remember adjusting so many lifters on the older cars. The newer cars usually have non-adjustable lifters so you might have to buy them. Don't worry, you'll get it fixed.
UDM-E46 Enthusiast is offline   Reply With Quote
Old 11-10-2012, 03:27 PM   #37
avincent52
My Ride: 325iT 5 speed/Sport
Yeah, this.
What I might do is take the thing for a PPI (even though it's already yours) finding a good mechanic to give you a proper diagnosis of the engine and the car's other issues for a modest amount of money, rather than trying to sell you a new engine.
Obviously you should have done that *before* you bought the car, but while you can't change the past, you can at least start gathering info in a sensible way now.
avincent52 is offline   Reply With Quote
Old 11-10-2012, 04:08 PM   #38
afstud
My Ride: 02 & 04 325xi sports
if you want a quiet diesel then get a 2012-13 jetta TDI, i drove one and you cant really even tell its running its so quiet.
2002 325xi Sport 5 speed Euro clears, short shifter, style 119 wheels
2002 GMC Envoy SLT (stock)
afstud is offline   Reply With Quote
Old 11-10-2012, 04:30 PM   #39
E46330iguy
My Ride: Supercharged 330i
Your car is FINE This is what diesels sound like if you think that is noisey take a look at how loud my truck is, Also reving a diesel while cold is bad for it, Just look up 24 valve diesel and youll see your car is quiet
Winter Authority When Hell freezes over,we'll play Hockey there too
Its fundamental to our nature, man must explore.
you've Met a terrible fate haven't you ?
KONI /Michelin/Stoptec/ Bimmerbrake / MTechII/AA Stage one (for now)
Questions about Header wrap? clickHere
Supercharger build thread click Here
E46330iguy is offline   Reply With Quote
Old 11-10-2012, 04:58 PM   #40
dovla15
Yes, that ticking/tapping noise you hear may be the only two things:
1. Bad injectors ! ( because of that, you have rough idle )
2. worn lifters !
dovla
