Old 08-21-2012, 06:17 PM   #1
william donovan
My Ride: 2000 323i
Tranny fluid change stripped the Torx head onn fill
Sux trying to get the fill plug out. Having a miserable time with this plug.
Had to drop the tranny mount to get the torx in and started to strip...and stopped! what now? Glad I did'nt drain it first. Need some advice
william donovan is offline   Reply With Quote
Old 08-21-2012, 06:24 PM   #2
Suseer
My Ride: Cayman S
Torx? The plugs are a 17mm socket.
Soak it in WD40 the plug and let it sit for awhile, make sure you are indeed using a 17mm, not a torx. Also use a breaker bar if you need more leverage.
http://m3.madrussian.net/diy_rp_tranny_fluid.shtml
I *think* it's the same as the M3.
Suseer is offline   Reply With Quote
Old 08-21-2012, 06:34 PM   #3
william donovan
My Ride: 2000 323i
not a 17mm (wish it was) its a 45 torx...on the fill-2000 323I (green sticker on tranny), anyhow Ideas on what to do to get it out?
Old 08-21-2012, 06:35 PM   #4
DangerousMind
My Ride: Sierra 1500 SLT
Isn't the tranny fill plug an 8mm allen? Anyway, I would get a set of pipe extractors and you should have no issue getting it out. http://usatoolsinc.com/5pcironpipeex...rset18-34.aspx Make sure they are pipe extractors and not bolt extractors as pipe ones are nice and shallow.
DangerousMind is offline   Reply With Quote
Old 08-21-2012, 10:00 PM   #5
SeattleGraugrun03
My Ride: 325i, E34 M5
Ouch
Sorry to hear that... that fill plug location is a nightmare. I did a drain/fill, with a filter change and believe that's the green-label GM tranny. I didn't do the tranny mount but used a wrench on the hex part of a stub torx socket, right before it got to the torx part.
If you stripped the torx I would try grabbing onto the exterior of the plug (there's a small lip you can try getting vice grips on) or have your trusty mechanic weld a nut onto the plug and get it undone that way and replace with new plugs. From my experience there was no space to get a screw extractor in there... but ymmv.
SeattleGraugrun03 is offline   Reply With Quote
Old 08-22-2012, 05:39 PM   #6
william donovan
My Ride: 2000 323i
love this car hate the stupid torx. can you weld anything on the plug?
Old 08-22-2012, 05:50 PM   #7
SeattleGraugrun03
There shouldn't be a reason why not... My mechanic has used that technique before. The tranny gets pretty hot anyway, I don't think a spot weld of a hex nut on the plug would be harmful to anything but the nut and plug.
Old 08-22-2012, 07:42 PM   #8
SweTurbo
Big Pimpin'
My Ride: 323i -98
Shouldnt be a problem welding a nut on the bolt.
There are several bolts used so "ITS A DAMN HEX DAMNIT" is not a valid reply
Old 08-23-2012, 03:32 PM   #9
william donovan
My Ride: 2000 323i
awsome! going to give an extraction tool a chance, then weld it.
Will let all know results
Old 08-23-2012, 07:24 PM   #10
william donovan
My Ride: 2000 323i
yup, welded no prob, drained and replaced gasket, filter fluid. came up a little bit short on fluid, but shifting is fine, still no reverse when at angle, will add more fluid and post results
