Old 08-21-2012, 09:34 PM   #1
badass1g
My Ride: yeller
Did i blow my clutch? Please help!
Errr
badass1g is offline   Reply With Quote
Old 08-21-2012, 09:56 PM   #2
Guest021715
Account closed.
Your first guess is my first guess as well.
Old 08-21-2012, 10:30 PM   #3
badass1g
My Ride: yeller
You think it is the slave or master? Hell i would be stoked it thats all it was. I am having a hard time finding a DIY for replacing clutch on this car. Anyone have a link?
Old 08-22-2012, 03:20 AM   #4
jaymemaurice
Location: Anchorage Alaska or Kitchener, Ontario, Canada
My Ride: 01 330ci, 03 Passat
Here is a good resource:
http://www.pelicanparts.com/bmw/tech.../tech_main.htm
Here is a good suplimentry thread:
http://forum.e46fanatics.com/showthr...ghlight=clutch
I'd check the slave cyl/oil level, then dig in and start removing parts. 75% chance whatever it is will involve dropping the transmission anyway.
Rain Sensor Retrofit: Here
Coupe Headline Replacement: Here
jaymemaurice is offline   Reply With Quote
Old 08-22-2012, 06:02 AM   #5
badass1g
My Ride: yeller
Lol funny you posted that link, thats the only one i found to show info on a DIY. However, it is not on an M3, are they the same as far as the process and everything? Or are there possibly differences? Thanks for your reply.
Old 08-22-2012, 06:25 AM   #6
choxor
My Ride: JDM
choxor is online now   Reply With Quote
Old 08-22-2012, 08:23 AM   #7
badass1g
My Ride: yeller
Old 08-22-2012, 08:30 AM   #8
Slopestyle
My Ride: E46 '02. 330Ci Coup
Does the M3 have a CDV? It took me awhile to get used to the CDV my first e46 had it deleted. While driving hold your c pedal down for a coont hair longer see if it pops in smoother. I thought the mechanics botched up a brand new clutch. Then my friend mentioned i have the CDV. HMMM??? changed my driving style a bit and boom. no notchy shifter, no forceful engagements. just a bit more patience. from then on i decided i like driving my car a bit mre since I'm never in a hurry.
Slopestyle is offline   Reply With Quote
Old 08-22-2012, 11:09 AM   #9
badass1g
My Ride: yeller
Its def not the CDV, there is in fact some type of mechanical failure. Actually, i was recently researching about the CDV delete thinking that might have helped my knotchy shifting, but now the car is not driveable at all so something definatly gave out on me yesterday. Just not sure what it is, yet.
Old 08-22-2012, 01:25 PM   #10
Slopestyle
definitely not CDV.
Old 08-22-2012, 04:24 PM   #11
badass1g
My Ride: yeller
Yep
Old 08-22-2012, 07:29 PM   #12
msane3
My Ride: 2007 335i
It's just like any other manual car. I replaced it on my smg myself without a lift in just a few hours. If the shop knows what it is doing, 4 hours of labor seems like an awesome deal if you don't want to do it.
msane3 is offline   Reply With Quote
Old 08-22-2012, 07:36 PM   #13
SweTurbo
Big Pimpin'
My Ride: 323i -98
All you need to remove is the exhaust,heatshield,driveshaft and then 9 torx bolts(e12,e14,e16. one of them isnt used but might aswell get all of them than be without one)
Remove electrical connections and the slave cylinder(2 nuts) and you pull back the tranny and inspect the mayhem.
Most likely you'll find nothing worng but since you're there and you dunno what the problem is just replace everything since they are wear&tear parts.
remember to replace the flywheel aswell if it hasnt been replaced in the last 90k miles
Old 08-23-2012, 04:27 PM   #14
metlic53
My Ride: 2003 BMW 330i
I have a guy putting in a new clutch kit and rear main seal, new fluid for $850, Christian brothers quoted me 1400 and a eurotypes shop said 1200, BMW said 1600
metlic53 is offline   Reply With Quote
Old 08-23-2012, 04:29 PM   #15
Guest021715
Account closed.
You should update "My Ride"
Old 08-23-2012, 04:33 PM   #16
metlic53
Mines a 2001 325i 5 speed with 130k miles. I'll go update
Old 08-23-2012, 04:35 PM   #17
Guest021715
Account closed.
I meant OP
Old 08-23-2012, 04:42 PM   #18
metlic53
Oh was wondering about that cuz I looked and it's there lol
