Old 08-21-2012, 09:35 PM   #1
smhapp
My Ride: 1999 328i E46 M52
Mystery part after replacing voltage regulator
Found this (see attached thumbnail) lying on the ground as i was cleaning up tools, etc post project. broken on the bottom, it appears to have some kind of oil lubricant/dirt. had a friend helping me with replacing the voltage regulator and it's possible something broke when he was working on it. Anyone recognize this piece?
i removed the air box, moved the power steering reservoir, removed the fan shroud, changed the belts, removed the alternator and back again.
thanks for any hints on this.
S
Name:	weird blue part for e46.jpg
smhapp is offline   Reply With Quote
Old 08-21-2012, 09:46 PM   #2
trj
My Ride: 325Ci
Headlight aiming knob, I am guessing.
Old 08-21-2012, 09:49 PM   #3
04330ciZHP
My Ride: E46 E90
Its the drain screw off the bottom of the radiator or part of it
Sent from my LG-P999 using Bimmer App
04330ciZHP is offline   Reply With Quote
Old 08-22-2012, 05:58 AM   #4
PerfectStorm01
My Ride: 320Ci
+1
Good call!
PerfectStorm01 is offline   Reply With Quote
Old 08-22-2012, 07:07 AM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
May have been caught under the car from some much earlier repair??
These engine bays are like black holes holding things from ancient history and will give up artifacts as you work within the engine bay removing shields, parts and repositioning things.
You will find long lost hardware, tools and small animals!
Old 08-22-2012, 07:10 AM   #6
scrace
My Ride: 03.5 M3
I lost a 3 inch screw driver in my 325....... That was 2-3 years ago.
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 08-22-2012, 08:03 AM   #7
Custom3
My Ride: HellRot 330CI
lol so true....
Old 08-22-2012, 09:48 AM   #8
smhapp
thanks guys. never did have a radiator repair though. guessing this might break during a coolant flush???
Old 08-22-2012, 10:13 PM   #9
04330ciZHP
My Ride: E46 E90
Maybe if over tightened
Old 08-23-2012, 01:11 AM   #10
My Ride: Lexus
So true. I've found some tools in my splash pan. I think member 'DMAX' also reported he found a 3-inch screwdriver... however he didn't find it in his car...
