Old 08-24-2012, 11:08 PM   #21
JohnIBarr01
My Ride: ZHP 6MT, Mk.6, Jeep
Originally Posted by //TRD power View Post
You know higher octane is less combustible? High octane just means a higher concentration of RETARDANT, to prevent premature combustion in like a ferrari or V8. IMO 87 is good for V/I6 and below. I always get the same mileage and no knocking. It's such a marketing scam for people thinking it's "cleaning better with higher grade" Wasting money on a rust bucket thinking it's Bentley status.
You know that you should take your turd of a TRD Toyota and move along, unless you can refrain from spewing any more BS like this, right?
Had a Camry rental today. Biggest pile of **** I have driven in a long while. We should have used more force.
Pat Summitt Foundation | VWvortex | V2Lab | Twitter | Facebook
Originally Posted by TheGreenspanator
Let me guess: This doesn't happen in Germany
JohnIBarr01 is offline   Reply With Quote
Old 08-24-2012, 11:32 PM   #22
MJLavelle
My Ride: 2001 BMW 330ci
Did you know that , depending on the pipeline and the company, some gas is shipped through the same line, just pumped in, one after the other? For example, they will shove 87 octane gas in, and then pump in the 89, then the 93. The operators on the other end know that X number of gallons coming out will be 87, then Y gallons, are 89, then Z gallons are 93. They remove a certain number of gallons between each batch, that is used in industrial furnaces, and other places that don't have many problems with multiple octanes.
For some reason, I thought this was interesting. I always assumed there were seperate lines. Then of course, multiple companies will buy the same gas, and mix in their additive packages. There is always some mixing of octanes, to some degree, which is why the the labels state that the octane is determined by an Average of the (R+M)/2 formula.
Old 08-26-2012, 08:36 AM   #23
alpine003
My Ride: BMW
Important to note that these days, a majority of the gas stations either have only two holding tanks or utilize two and mix both high and low octane gas on the fly at the pump. So they will mix 93 and 87 or 91 and 87 to achieve the 89 octane rating at the gas station.
Either way as others have pointed out, we should only be using premium per manufacturers recommendation.
alpine003 is offline   Reply With Quote
Old 08-26-2012, 09:48 AM   #24
jneumann
My Ride: 323i, 530i, Z4 3.0i
Send a message via AIM to jneumann
You really have no fvcking clue what you are talking about. Number of cylinders has absolutely nothing to do with octane requirement. You could run 87 octane in a Veyron if you swapped in low compression pistons. You could also run 93 and see a noticeable improvement in power (given a proper tune) in your crapsicle of a car with higher compression pistons swapped in. There are actually dyno proven gains from running higher octane fuel in modern BMWs. And no, you don't notice knocking in modern cars that require 91+ because the DME adapts to crappy fuel and drops power output to save the engine from blowing itself up.
I'm usually not one to insult people's car choices, but if you come in here acting like you know everything, you will be put in your place.
E46 323i Sport/5 speed | 243k miles
E85 Z4 3.0i Sport/6 speed | 117k miles
E83 X3 3.0i M-Sport/6 speed | 130k miles
E39 530i M-Sport/5 speed | 237k miles
Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ
jneumann is offline   Reply With Quote
Old 08-26-2012, 10:06 AM   #25
psan03
My Ride: 2003 BMW M3
+100 ^^
Sent from my SGH-I997 using Bimmer App
-03 Silver Grey 325i-
Originally Posted by tifreak View Post
wire a car bomb to your ignition, when he goes to steal it you'll know :shhh:
psan03 is offline   Reply With Quote
