Old 08-23-2012, 03:36 PM   #1
bimmerman11
My Ride: 2005 330Xi
Send a message via AIM to bimmerman11
How much will labor cost to replace belts and pulleys?
If I buy the belts and pulleys kit from Tischer, how much should it cost to do the job? How many hours should it take?
My friend's friend will probably do the job but I don't know what a reasonable price is.
Thanks.
bimmerman11 is offline   Reply With Quote
Old 08-23-2012, 03:37 PM   #2
3coupe
My Ride: 330Ci
Someone that knows what they are doing, it should be less than an hour, two hours if they run into some problems.
3coupe is offline   Reply With Quote
Old 08-23-2012, 03:46 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Pulleys to replace the idler and tensioner, or under drive pulleys?
I hope you're at least doing the idler and both tensioner pulleys while you're there...and you could do this yourself, you know, for maybe 2 hours of reading time and $50 in tools...parts are $40 for belts...maybe $60 for the pulleys I mentioned. I did all three pulleys in about 15 mins or so...maybe 20, but I have a manual so it takes a few minutes less than someone with automatic (and for auto, you need 1 or 2 special tools)
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-23-2012, 03:50 PM   #4
moiz21
My Ride: 1999 323i 5-SPD
Talk to Solidjake. He lives in NY and could probably do it if he has time for a fraction of what a shop would cost.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 08-23-2012, 03:51 PM   #5
bimmerman11
My Ride: 2005 330Xi
Hey dmax. I believe the parts you listed are included in the Tischer kit. The kit is $400 so it better. I have an auto and I'm not handy around cars so it's better to have my friend's mechanic do this job for me.
Old 08-23-2012, 03:52 PM   #6
idoc330ci
My Ride: 2003 330ci
Definitely a DIY. Might take a few extra minutes if you have an auto like me. You just need a 32mm wrench and a rubber mallet to remove the fan clutch nut so the fan and the shroud needs to come out. That was the only pita. Good luck.
idoc330ci is offline   Reply With Quote
Old 08-23-2012, 03:53 PM   #7
bimmerman11
My Ride: 2005 330Xi
Moiz.... That's a great idea. Thanks
Old 08-23-2012, 03:55 PM   #8
dmax
dmax's Avatar
So you're underdriving it? I don't think you'll notice anything, but check as the pulleys I mentioned are really the only ones that will go bad and need replacement. I recall one cracked PS pump pulley...and I read a lot here!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-23-2012, 04:00 PM   #9
bimmerman11
My Ride: 2005 330Xi
Dmax. I think the kit comes with tensioner and Idler pulleys. I don't think it comes with underdrive pulleys.
Old 08-23-2012, 04:10 PM   #10
dmax
dmax's Avatar
If the kit is $400, then you're paying for two tensioners, which you probably don't need and who knows what else.
Search thread titles for 'pulleys' and you'll get PNs for all three as Dayco/Autozone pulleys...$60 or so for all three. Belts...$40 or so. Not sure where the extra $300 is from if it's not tensioners...which again, you probably don't need. If the belts run flat between pulleys, then you just need the tensioner pulleys, not the tensioner itself.
So, I figure I deserve about half of what I just saved you, but I'll accept a beer next time I'm in Staten Island!
See me in June!
dmax on Facebook
Mangofy your E46!
