Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 10-06-2012, 03:22 PM   #21
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Originally Posted by RayPooley View Post
Our roads in teh Uk are ferkin terrible. Collectively the UK driver pays about £40Billion in motoring taxes every year and only £4Billion gets spent on the road network. The rest goes into the government's pot to pay foreign and home grown deadbeats to sit on their lazy arses and breed. That's what happens when you let the socialists get a grip. They pay the dead beats to vote for them.
Sounds familiar...
Originally Posted by Mango View Post
reputable name brand only. no non-name, made-up name ebay teen baggy pants stance meets sideways stickers baseball caps neon sunglasses coilovers
Old 10-10-2012, 08:18 AM   #22
LeMansteve
Update: As stated before, re-balancing the wheels has reduced the steering wheel vibration by 80-90%. However, I am still experiencing some through-the-seat vibrations. The vibration is noticeable starting at about 30mph. It increases in frequency with speed but is a little more tolerable at highway speeds. Since I don't have access to a lift or regular access to ramps or a jack, I'll probably have my local independent mechanic try to diagnose it. My guesses are either the old runflat tires are just beat up and out of shape, or it is a giubo, driveshaft bearing or rear drive axle issue.
Old 10-15-2012, 08:58 AM   #23
eksath
My Ride: 02 330ci TopazBlue
Update on my case:
Closer examination of my rims by the shop, showed that 2 of them (front) are bent. The two in the back have slight distortions too. Highway near my house is under construction hence a lot of lane changes and resurfacing with bumps/dips etc. I presume that is the culprit.
I put the front wheels to the back for the time being while i get the fixed and the vibrations are reduced tremendously. Still a slight vibration (understandably). Will get these fixed asap. Just an update to others as an FYI.
www.starracer.us
People believe in Ghosts, UFOs, talking to the dead, advertising, magic, curses, voodoo dolls, Elvis' death faked, the Great Pumpkin, Tupac still lives, the WWF, that all the moon walks were staged, real unstaged audience questions in talk shows, JFK's conspiracy assination theories, TWA 800 shoot down conspiracy theories, the image of the Virgin Mary appearing on a left over pizza, that Dr. Laura has no bias, that homosexuality is a choice, the guests on Jerry Springer, the TV illness of the month, that guns don't hurt people do, that CNN doesn't hype stories, the Osbornes not being staged, that a pill can make you loose weight without ever dieting or excercising, that there's a cure for baldness, aging and being short, that Britney Spears doesn't lip sync, That KFC is a healthy food choice, that the British Royal family isn't disfunctional, that there really were weapons of mass destruction in Iraq, that all Arabs are the same, that Muslims encompass everyone from Indonesia to Morocco and they are all extremists, that all Americans are the same, that's it's always cold in Canada, that cigarettes aren't addictive, that it's ok to drink but not ok to smoke up.........and on and on and on and on...... so what on Earth makes anyone believe that there is something unusual about people fearing the number 13 or astrology?
eksath is offline   Reply With Quote
Old 10-19-2012, 08:39 AM   #24
crackersmasher
My Ride: 99 323i
If you guys come up with any end results please keep them coming as I am having the same issue.
99 323 has 175k. I recently replaced my tie rods, front control arms and FCAB. Got an Alignment, tires balanced and rotated. Tires are only 6 months old and there is no irregular wear pattern. Front bearings were replaced about 40k ago and I have never replaced struts.
The car ran smooth before I pull the wrench out and started replacing everything.
I too am experiencing the vibration above 60mph. After alignment it still veered to right so I took it back. Right after balancing the front left had thrown a weight so I thought that would be my issue but I had them rebalanced and the steering wheel vibration is still there, although it does seem to disappear at times.
crackersmasher is offline   Reply With Quote
Old 10-22-2012, 09:52 PM   #25
325xittt
My Ride: 2003, 325 XIT
Have to disagree about alignment not causing a shake. I just replaced CABS, control arms and ball joints, Put new tires on and had them balanced on round wheels. The car had a noticeable shake in the steering wheel between 60 to 65 mph. Had it aligned and presto smooth as butter no shake what so ever. There are many reason for wheel shake and alignment is one of them.
325xittt is offline   Reply With Quote
