Bosch 42lb/hour Green Giant Fuel Injectors Set of 6 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Engine & Performance
Old 08-24-2012, 05:08 PM   #1
WALKD U
My Ride: Just Fast!
Bosch 42lb/hour Green Giant Fuel Injectors with EV1 Connector
Genuine Bosch Green Giant 42lb/hour Fuel Injectors
They have about 2k on them.
These superb Bosch injectors gained notoriety for their excellent flow and response characteristics in modern Volvo turbo applications. The characteristics necessary to meet stringent European emissions laws while supplying a wide dynamic flow range produces and excellent, balanced injector. The result was so popular in the aftermarket, it was nicknamed the "Green Giant" Injector.
These injectors flow 43 lbs/hr at 43.5 PSI ( 3 BAR ) and much more at higher PSI! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths. This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector. These injectors represent the most current Bosch engineering and are used on many high power turbo oem applications.
These injectors are able to function at high fuel pressures and don’t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures and in fact, that is exactly what they were designed for!
Engine performance and running quality are enhanced through the optimized spray pattern. Unlike competitors “pencil stream” high flow injectors; these High Flow injectors utilize a split / wide cone spray pattern for improved mixture preparation and atomization. This results in lower BSFC and better idle quality than many injectors with less flow.
Features:
•Genuine, reliable Bosch Injectors
•Excellent response characteristics
•Robust Design
High Impedance
•Low Impedance performance characteristics with High Impedance Compatibility
Specifications:
•Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
•Spray Pattern: Dual Spray Wide Cone / Split Cone
•Electrical Connector: EV1
•Fitted with Viton upper and lower o-rings.
•Static Flow Rate @ 43.5PSI (300kPa): 43 lb/hr
Applications:
•Volvo & many European makes
•Many Japanese makes
•Made for high pressure, harsh environment turbo & supercharged applications!
Cross Reference:
•Bosch 0 280 155 968 ( 0280155968 )
•Volvo 9202100
Asking $225 Shipped OBO
-Trip
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 09-21-2012, 11:42 AM   #2
WALKD U
My Ride: Just Fast!
Bump
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 10-29-2012, 09:54 PM   #3
WALKD U
My Ride: Just Fast!
bump
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 10-31-2012, 06:01 PM   #4
joshzhp
My Ride: ZHP--Stock
bump
joshzhp is offline   Reply With Quote
Old 12-07-2012, 10:20 PM   #5
Czapa11
My Ride: S4
Hey intrested in those mail me
koles11@yahoo.com
Czapa11 is offline   Reply With Quote
Old 12-08-2012, 01:15 AM   #6
WALKD U
My Ride: Just Fast!
Email sent
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 12-13-2012, 12:02 PM   #7
daveion2002
My Ride: 2001 330i
Hey wondering if these will fit my 2001 330i? and whats your reason for getting rid of them?
daveion2002 is offline   Reply With Quote
Old 12-13-2012, 08:22 PM   #8
WALKD U
My Ride: Just Fast!
Yes they will fit but will a need 4 spacer and longer bolts on the fuel rail. Body is alittle longer. I am going with bigger injectors in the future.
-Anthony
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 12-14-2012, 02:37 PM   #9
daveion2002
My Ride: 2001 330i
alright, I may be interested. Where would i be able to get the spacer and longer bolts? does it effect the engine/ fuel economy also i don't have any forced induction just a AFE intake
Old 12-15-2012, 02:24 AM   #10
WALKD U
My Ride: Just Fast!
These injectors are ment for boost on our cars. Why are you wanting to upgrade?
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 12-15-2012, 11:49 AM   #11
daveion2002
My Ride: 2001 330i
Nah not yet... maybe someday. My injectors are just going out and I dont want to wait for them to be cleaned if i could just get a set for such a cheap price. Sounds like i should just send them out though.
Old 12-15-2012, 10:53 PM   #12
WALKD U
My Ride: Just Fast!
I have a set of stock for $150 has 75k on them.
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 02-10-2013, 08:21 PM   #13
WALKD U
My Ride: Just Fast!
Bump
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 07-25-2013, 08:38 AM   #14
WALKD U
My Ride: Just Fast!
Bump
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 07-29-2013, 11:29 AM   #15
WALKD U
My Ride: Just Fast!
Re: Bosch 42lb/hour Green Giant Fuel Injectors Set of 6
Bp
Sent from my GT-I9505 using BimmerApp mobile app
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 08-01-2013, 11:50 AM   #16
WALKD U
My Ride: Just Fast!
Sold
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
