Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 08-24-2012, 08:27 PM   #1
zhenkaaaM3
My Ride: Fst'r then your e46
Lambda Probe 4, what is this?
Scanned an e36 m3 with a code "Lambda probe heating probe 4".
What exactly does this mean?
Thanks in advance.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 08-24-2012, 08:29 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
Isn't a lambda probe an O2 sensor?
http://en.wikipedia.org/wiki/Oxygen_sensor
They have to heat up to work effectively, so they contain a heating element. This is saying that the heater for it is broken. I'd imagine it is built-in to the sensor and you'd just need a new one.
http://www.pelicanparts.com/cgi-bin/...-1-735-500-M14
Old 08-24-2012, 08:36 PM   #3
zhenkaaaM3
well ok, do you mind telling me if its post or pre cat?
Eugene
Old 08-24-2012, 08:41 PM   #4
Zell
Zell's Avatar
Well, just from pure guessing, I'm going to assume that 1/2 are pre, and 3/4 are post. It seems like that'd make sense. I'd be surprised if 4 was a pre.
Old 08-24-2012, 08:44 PM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Eugene, I'd be guessing but it sounds like it's be bank 2 and post cat sensor...
But, 02 sensor codes often seem to come about because of other things pretty often...though with only one 02 code (assuming the heater is built into sensor) that might be more reliable.
I do know that cats on an older 750 have heaters independent of the sensor, but don't recall that on an e36.
HTH...good luck!
See me in NYC in May!
Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m.
dmax on Facebook
Mangofy your E46!
Old 08-31-2012, 06:29 PM   #6
zhenkaaaM3
Can anyone tell me which of the sensors is bad? Location? Post or Pre? Which sensor of the particular location?
and Zell, I have a 99, so would that mean I need this instead?
11-78-1-427-884-M209
Oxygen Sensor, fits on CATALYTIC or on MANIFOLD, 990mm, 323i/is/iC (1998-99), 328i/is/iC (1996-99), M3 w/ 3.2L (1996-99), sold individually. NOTE: Each model-year listed requires varying quantity. Please check your car first before ordering.
Eugene
Old 08-31-2012, 11:51 PM   #7
zhenkaaaM3
Ttttttt
Eugene
Old 08-31-2012, 11:57 PM   #8
Zell
Zell's Avatar
I know very little about the E36, but I know it is not really all too far off from the E46. If it says you need a specific O2 sensor for a '99 E36 M3, I would trust that.
I do not know exactly which location it is, but I know it is post-cat. If i were you, I'd check E36 forums. If nothing comes up, I'd unplug the wires from the post-cat sensors and see if "Probe 4" comes up for a secondary error (probably something along the lines of 'Lambda Probe (# here) Signal not plausible'). If you get a matching number, then you know just which one it is.
Old 09-01-2012, 09:48 PM   #9
zhenkaaaM3
Very smart thinking. I will try that out.
Eugene
Old 09-02-2012, 06:08 AM   #10
dmax
dmax's Avatar
#4 would be the post-cat sensor on bank 2...follow the pipe back from cylinders 4-6...it has to be that one.
dmax on Facebook
Mangofy your E46!
Old 09-02-2012, 10:38 AM   #11
zhenkaaaM3
Doug, would I need to purchase #2 or #1?
http://realoem.com/bmw/showparts.do?...81&hg=11&fg=50
Eugene
Old 09-02-2012, 11:08 AM   #12
dmax
dmax's Avatar
Eugene,
From the diagram, I'd say #2, but that'd be an educated guess...again, post cat sensor, so that's the only one...and that's assuming that's your issue...which does seem likely.
I'd wait for confirmation from someone who isn't guessing, just to be safe!
dmax on Facebook
Mangofy your E46!
Old 09-02-2012, 11:09 AM   #13
dmax
dmax's Avatar
...and actually, have to add that that realoem diagram was for e46, not the e36 you said you got the code on...so my new answer is 'neither'!
The image, though, should be similar for e36...but the PN is probably different.
dmax on Facebook
Mangofy your E46!
Old 09-02-2012, 11:16 AM   #14
zhenkaaaM3
then it must be #1 in this diagram. Lambda is aka o2 sensor?
http://www.realoem.com/bmw/showparts...71&hg=11&fg=50
also take a look at this diagram, #15 and #16
http://www.realoem.com/bmw/showparts...53&hg=18&fg=10
Eugene
Old 09-02-2012, 11:41 AM   #15
dmax
dmax's Avatar
#16 would be post cat sensor...so that...not the #1 or the #15...again, on the assumption that the #4 sensor code you got was bank 2 sensor 2...can't imagine it'd be anything else.
Pricey bugger, but I know you can find them for under $100 around.
Also, first I'd make sure that the connections are good. Have you cleared the codes and the same one returned?
dmax on Facebook
Mangofy your E46!
Old 09-02-2012, 12:09 PM   #16
jfoj
My Ride: 330CiC, M5, X5, E93
Check fuses first, many of the O2 heater circuits have individual fuses.
If the heaters have individual fuses, you may be able to just pull a fuse to narrow down which O2 sensor is which?
Old 09-02-2012, 01:37 PM   #17
zhenkaaaM3
Yes doug. I even cleared it twice to make sure. It popped up right away after i turned car on for the 2nd drive cycle.
Eugene
Old 09-06-2012, 10:26 PM   #18
zhenkaaaM3
Its actually lambda probe heating probe 4. so the heater portion of the sensor I guess malfunctioned. Anyway to fix it without replacing the whole sensor? Maybe add a resistor to it so it gives off "good" readings?
