Go Back   E46Fanatics > E46 BMW > Regional Forums > Australia
Australia
Old 08-25-2012, 12:37 AM   #1
ppmz
My Ride: 330i
DIY E46 Media Centre: MP3, videos, Digital Radio, Digital TV?
So I bought me one of those Raspberry Pi boards for $25 (actually more like $40 in Australia after shipping/gst etc) and hooked the video-out to my car. It works
It won't be easy, but potentially you could do lots of things with this, without ripping out your factory equipment:
1. MP3s with album art, playing from SDCard or USB
2. Videos off USB storage
3. Digital Radio
4. Digital TV? (antenna will be a problem)
Stay tuned, an interface to the headunit buttons is the next step.
ppmz is offline   Reply With Quote
Old 08-25-2012, 12:56 AM   #2
selien
My Ride: 330CI
Send a message via ICQ to selien Send a message via AIM to selien Send a message via MSN to selien Send a message via Yahoo to selien Send a message via Skype™ to selien
Thats sweet, I was going to build myself a carputer, then I couldnt be bothered, maybe one day.
Digital TV aerial isn't a problem, as long as you conceal and run it somewhere to obtain a signal.
I know I can hook up a usb DTV dongle to my Dynavin which has a aerial built in and it will work fine.
selien is offline   Reply With Quote
Old 08-25-2012, 01:01 AM   #3
Jall
My Ride: 328Ci
I built a carputer in my E30, **** was tight. Wanted OEM look with minimal fcking around in the E46 though so went Dynavin.
Raspberry Pi has been interesting me for a while, mainly as a low cost HTPC/XBMC box though. I'm interested to see how you interface it.
Jall is offline   Reply With Quote
Old 08-25-2012, 09:54 AM   #4
JS330
My Ride: '01 330Ci 3 Pedals
can you use the headunit buttons to control it?
JS330 is offline   Reply With Quote
Old 08-25-2012, 11:52 AM   #5
shook
My Ride: E46 328ci
Where did you get it? I'm interested !
shook is offline   Reply With Quote
Old 08-25-2012, 09:03 PM   #6
Ballistic325
My Ride: slow and steady
Interested in this project.... Great idea! I received my Pi a little while back but haven't had time to play with it yet.
What's your background? Are you into programming?
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 10-06-2012, 05:15 AM   #7
ppmz
My Ride: 330i
Yes I know how to program a linux box, so that shouldn't be a problem
Started designing a Raspberry PI to BMW interface board. Some features:
1. Can switch video between three sources using a relay: (a) Stock BMW menus (b) Raspberry PI (c) reversing camera.
2. Can read/write ibus while the PI isn't powered or booted up using an 8-bit microcontroller.
3. Provides switch-mode power to the PI and a way to turn it off automatically when you lock your car (don't want it draining your battery).
4. Provides two extra relays to control extra stuff: e.g. Power to your reversing camera (if you use it while not reversing), garage opener.
5. No need to rip out or wreck any factory equipment - except maybe the CD changer.
Hopefully will get a board fabricated soon. I need to quit my day job to have more time to tinker with BMW electronics
Old 10-06-2012, 05:30 AM   #8
ppmz
My Ride: 330i
From Element 14.
When my board is done, yes.
Old 10-06-2012, 07:46 PM   #9
Shonky
My Ride: 2004 E46 M3
Quite a bit more expensive than a Raspberry Pi solution but this one is basically plug and play carputer for E46 including ibus interface automatic switching on Aux etc.
http://ac-services.eu/shop/product_i...83--e85-.html&
Shonky is offline   Reply With Quote
Old 01-09-2013, 02:54 AM   #10
webdj
My Ride: e38
i have raspberry PI too... i try to connect in to my E38, I think we have similar protocols=) I'll be watching this topic=)
ppmz, based on what you want to do interface board?
P.S. Sorry for my english=) i am from russia=)
webdj is offline   Reply With Quote
Old 01-09-2013, 04:17 AM   #11
ppmz
My Ride: 330i
Yes, it's all IBUS. Programming will be a big part of it, can you code any?
Interface board will provide power (and standby) to Pi, so it doesn't drain your car battery. Also it will switch video source via a relay between 1) BMW MK4 computer 2) Reversing Camera 3) Raspberry Pi. It's got a small 8-bit Atmel microcontroller to do this and uses very little power (around 500 μA) so can be left running 24/7.
I have this all working, but no software to do anything useful yet. I guess it will require some hacking with xbmc.
Old 01-09-2013, 04:56 AM   #12
[SeN]
My Ride: 2002 M3 Imola Red
Interesting stuff... subscribed!
Bilstein PSS10 /// Vorshlag Camber Plates /// Turner Motorsports RSM /// Rogue Engineering Octane SSK w. ZHP gear knob /// Dice MediaBridge 1500
[SeN] is offline   Reply With Quote
Old 01-13-2013, 05:01 AM   #13
pythonis
My Ride: BMW 2000 323CI
I had this same idea! how cool is it? I just got a wifi obd2 plugs and got them hooked up to my ipad for dashcommand. Does the raspberry pie have wifi? if so,you could do that as well for like $28 from ebay if you have the standard 16pin obd plug. this is so awesome! will have to defiantly get one now, like 5 pies actually I think...
pythonis is offline   Reply With Quote
Old 05-03-2013, 07:35 AM   #14
ppmz
My Ride: 330i
OK so I made some progress, here's a teaser video :
Old 05-03-2013, 07:42 AM   #15
DeclanM3
My Ride: M3
Very cool for an interface that was made in 1970 according to the date
Sweet features. Seems a bit slow though and what happens when you turn the car on (say after getting petrol) do you need to go through all the menus to get your music playing again?
Originally Posted by CortinaD View Post
You could fill your engine with water so the oil rises to the top and then scoop it out.
Just because you wear a skirt and put lippy on it doesn't mean you are a girl Peter.
DeclanM3 is online now   Reply With Quote
Old 05-03-2013, 10:22 AM   #16
JS330
that is awesome! want to make me one
Old 05-05-2013, 01:16 AM   #17
ppmz
My Ride: 330i
Jeeze, you're a tough taskmaster, I only just got the basics going. It was slow because there was a stuck program running in the background on the Raspberry Pi, I've solved that now. It's about 3-4 times quicker when clicking things.
The hardware has power even if you lock the car, just gotta add some software that gracefully shuts down after ~5 mins of inactivity.
Sure I'll make you one. It took me 6 months, so the invoice will be $50,000 or so (though there's $10 worth of parts on the board . If you're handy with a soldering iron and have lots of patience I can give you the plans.
Old 05-05-2013, 01:19 AM   #18
JS330
I'm quite handy with the solder, would love to see the plans for it!
Old 05-05-2013, 01:23 AM   #19
DeclanM3
My Ride: M3
That's good that you managed to get it going quicker. Seems like a cool solution for music videos etc. I still think Intravee II is the best for music though.
Old 05-05-2013, 01:51 AM   #20
JS330
so would it be possible to run this in conjunction with my GROM plugged if i had a switch where the cd changer is?
