Sponsored by BAVSOUND
Old 04-27-2017, 09:11 AM   #1
Diazz
My Ride: Bmw 325Ci -01
Small navigation stops working sometimes.
Hello!
I've got a 325ci from 2001, and i have the small navigation system, with navigation and cd changer in the trunk. (same size as the Business CD player but with a small navi screen)
And the other day it just didnt start, nothing worked, the radio died aswell.
So i thought it was dead, but sometimes when i start the car it starts as if nothing has happened. And then the next time i start the car it doesn't start.
Any ideas? can't find another unit like that here in Sweden and i refuse to install a normal aftermarket stereo.
If the unit itself is broken, could i possibly buy a normal Business player instead? i can't afford the avon/eonon units.
Thanks!
Diazz is offline   Reply With Quote
Old 05-09-2017, 11:42 AM   #2
Diazz
Sorry for bumping this, but it's completely dead now and driving without any music is a pain, and i wonder what i can replace this with? preferably something with Aux/bluetooth, but just a radio would be welcomed right now. Like i said in my first post i can't afford the aftermarket avon/eonon etc, but hopefully i could use a Normal business player?
Thanks a bunch!
Old 05-10-2017, 04:18 AM   #3
Onizukachan
My Ride: `04 M56 Touring
Never seen one of those.for curiosity do you have any pics of it?
If I were to give my Touring a first name, I'd probably name it "Alan".
Mostly because I like puns.
DIY: E46 Touring TV Tuner Install/Mounting
DIY: Wiring City Lights, Rear Fogs, and Rear Camera in a Touring
Onizukachan is offline   Reply With Quote
Old 05-10-2017, 01:35 PM   #4
Diazz
http://img.mysoocuu.com/photo/ycarli...1110251125.jpg
Old 05-10-2017, 02:04 PM   #5
JJR4884
My Ride: BMW
Originally Posted by Diazz View Post
Hello!
Thanks!
At this point given how dated that unit is, I'd say look for an Eonon or Dynavin replacement. That unit you have is a fossil... the cost of another one or troubleshooting will probably cost more than a brand new Eonon
JJR4884 is offline   Reply With Quote
Old 05-10-2017, 02:10 PM   #6
Diazz
I actually managed to get one for free on a Swedish BMW group, the guy said he got it when he bought an e46 but didn't have the car. So i'm hoping it will work, i want a Eonon or similar but the budget just doesn't allow that atm.
Old 05-10-2017, 02:44 PM   #7
JJR4884
My Ride: BMW
Well for what its worth, the Business CD is different wiring, so you cannot plug and play. If i'm not mistaken, the Eonon/Dynavin units do have plug and play options for e46's that are equipped with Navi if i'm not mistaken.
I would look into them to see what your options are. As far as plug and play options with an updated 16:9 BMW screen (the large one) I have no idea if that would work, in case this was another option being considered.
Did you check all your fuses and connections for the radio/nav?
Old 05-10-2017, 03:06 PM   #8
Diazz
Thank you for the information, i still wanted one of those but now i know i can't use it, luckily the one i got is the same model as i have, with a miniature navigation system.
Yep, no problem with fuses etc, and if the new one doesn't work i know for sure there is a different issue entirely. I also have an issue with the button on the turning signal stalk, i can't change info on the screen, i hope it isn't connected somehow.
Old 05-10-2017, 03:12 PM   #9
JJR4884
My Ride: BMW
What are we talking about here? There are 4 different options for you so let me clarify. In an earlier post, you mentioned you got another (small) BMW navigation for free? did you try to install that yet?
Small Nav OEM BMW - Plug and play
Large Nav OEM BMW - Not sure if plug and play
Business CD OEM BMW - not plug and play, pointless to spend the $$$
Eonon/Dynavin - should have option to plug and play with OEM nav equipped models
The turning signal stalk... you can't change the info on the screen. What screen? To my understanding, this info button changes the info in your instrument cluster. Time, temp, MPG, Avg MPG, Avg Speed, etc. What does this have to do with your Navigation unit?
Old 05-10-2017, 03:43 PM   #10
Diazz
I'm sorry if i was being unclear (English is not my first language)
I wanted to use the Business CD, now thank to you i know it won't fit so i don't even have to think about it.
The unit i got was the same that i have, the small Nav unit. And no i have not yet installed it.
Exactly, the screen in the cluster, the thing is that that is the exact same info i get in the navigation unit, which is why i thought they may be connected and with that something else was broken.
Old 05-10-2017, 04:10 PM   #11
JJR4884
My Ride: BMW
Got it
Old 05-10-2017, 04:12 PM   #12
Onizukachan
Well, the Nav drive has to be coded to monochrome to work with the monochrome. But it shouldn't affect the radio. I have the feeling this is almost like the Nav with standalone screen. You have a normal radio that powers the speakers and the display is just a display... no separate bm24 radio module, plus Nav, to a display like the 4:3 and 16:9 Nav.
I'd still suggest going and looking at the mk2i to mk3 upgrade PDF to confirm that. If it indicates you have no bm24, then it is just a regular self powered radio with a small display driven by the Nav built in. If you do have a bm24 it still could be just a headie problem.
Old 06-06-2017, 08:49 AM   #13
Diazz
A small update, i tried the other Head-Unit, it did not work, i pulled the fuses (again) and the weird thing is that #41 flashes when i put it back in? Still not working.
Today i took apart the module in the back, a black box under the GPS/Cd-Changer. Checked all the solders and also capacitors etc, nothing wrong with it. Any other ideas? Thank you so much for any input!
Old 06-15-2017, 12:50 AM   #14
Diazz
Another little update, i realized that the cruise control also stopped working, and i read somewhere in a thread when i googled that somebody asked OP if his Cruise Control works, but now i can't find that thread. Anyhow, yesterday it did start again, first time in weeks, it ran for about 2 minutes, one strange thing though was that my volume buttons on my steering wheel changed the radio stations? Tried resetting Kbus by leaving the battery off for 2 hours, no result
Thanks again!
Old 06-15-2017, 08:26 AM   #15
markusmarkus
My Ride: 2001 330Ci
Google "BMW E46 hidden obc functions." Test #9 shows the voltage as seen by the computer. Check and report back the voltage when the:
- ignition is in the "run" position but with the engine off
- engine idling
- engine reviving at 2000rpm.
These cars are rolling computers and wacky voltages create wacky issues.
Old 06-16-2017, 02:30 AM   #16
Diazz
- engine idling
Thank you!
Ignition on: 125
Idling: 141
2k rpm: 142
