Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 69 votes, 4.99 average.
Old 10-13-2013, 05:01 AM   #81
PeteAU
My Ride: 330i
Originally Posted by theos View Post
Hi all,
just found this project and I'm really excited about it.
I own a Range Rover l322, which is manufactured by BMW and equipped with the same radio.
Currently I have a MK3 navigation, but I'm planning to upgrade to a MK4 soon.
Do you know if this system would work with a DSP amp? I Don't have a coax-connection on my CD-changer.
I'm a software engineer and as a hobby I like to play around with electronics. I wouldn't mind to do some hacking on it before it works.
thanks!
Theo
I'm not sure. If your cd-changer sends out analogue audio then it's likely to work.
PeteAU is offline   Reply With Quote
Old 10-13-2013, 05:32 AM   #82
theos
My Ride: Range Rover l322
okay, I'll check it and will share the results.
If this won't work, I'll might want to try to use tape, as webdj suggested.
theos is offline   Reply With Quote
Old 10-27-2013, 02:38 AM   #83
PeteAU
My Ride: 330i
PiBUS 2
Hi Guys,
The original board for this was a little too complicated so I've decide to revise it.
The new version works much the same way, but has a lot less parts to solder, no ribbon cable (plugs ontop of the Pi) and allows you to plug the BMW 6-pin audio straight in.
I'm thinking of putting a DIY-solder kit together, like the image below and just trying to gauge the level of interest. It would come complete with all components (except the Pi itself) and a pre-programmed micro-controller, so it's dead easy to put together.
This is not a big money making scheme, so it'd cost just the price of the parts plus a few bucks to keep me interested
Who'd buy one and how much would you expect to pay?
ID:	532399   Click image for larger version
Old 10-27-2013, 04:27 AM   #84
JS330
My Ride: '01 330Ci 3 Pedals
I'd probably send you a fifty or something
Originally Posted by DeclanM3 View Post
I hope he isn't using Pirelli condoms..
JS330 is offline   Reply With Quote
Old 10-27-2013, 04:59 AM   #85
NumbaOneNewb
My Ride: 2003 330CI Silver
DIY E46 Media Centre: MP3, videos, Digital Radio, Digital TV?
I like your innovative idea as a whole however it has one drawback. Since you're targeting those who wish not to change the factory look, the crowd you're left with are people who already have a navi unit or got one for dirt cheap since a used one costs so much it can't be justified. The solution for the rest is to go with an aftermarket touchscreen and even better has the capability to allow the mirroring capabilities of your phone. Like my pioneer app radio 2 it gives full access to everything on my galaxy s3 or iPhone 4. It's like an extension and enlarged version of my phone in front of me. I paid $230 for it but it was a previously opened item at best buy
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 10-27-2013, 05:43 AM   #86
JS330
Most of the E46's in Australia have a Television Module and Monitor...well they came standard on all 330ci/i 's and most m3's
Old 10-27-2013, 06:06 AM   #87
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
Originally Posted by ppmz View Post
Hi Guys,
This is starting to sound good to my lazy arse!
E46 Coupe is offline   Reply With Quote
Old 10-28-2013, 01:36 PM   #88
jararak
My Ride: e39 530d
ppmz perfect, i'm interested in this diy solder kit.
jararak is offline   Reply With Quote
Old 10-28-2013, 04:30 PM   #89
E46 Coupe
E46 Coupe's Avatar
Let us know the ball park range Peter
Old 10-29-2013, 12:22 AM   #90
Ballistic325
My Ride: slow and steady
Great work on this so far.... I'm interested too.
What are the pre-reqs to make this work? OE TV module? As Newb suggested, maybe the ability to output to a generic touch screen would be use too.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 10-29-2013, 05:01 AM   #91
PeteAU
My Ride: 330i
Around $60 might be do-able. Still need to test that the new design works and then I can add up the cost. If you consider a Resler board costs 29.90 Euro and basically does nothing, I guess it's not bad.
Yeah, just the TV module and cables for CD-Changer - most cars should have them in the boot I think.
Old 10-29-2013, 04:35 PM   #92
E46 Coupe
E46 Coupe's Avatar
I'm ok for you to use my M as a guinea pig I'm next door to you in Blackburn. $60 region is quite fine IMO as adding the pi will still keep it under $100.
Old 10-30-2013, 04:21 AM   #93
jararak
My Ride: e39 530d
maybe there it is already discussed before, but why it is connected via reverse cam?
just to start picture after device boot?
it is possible to connect it via AV-in?
Old 10-30-2013, 04:28 AM   #94
Davew
My Ride: 2004 330ci Msport
Av in is picture and mono sound, using reverse camera input gives you video, cd in gives you stereo sound
Davew is offline   Reply With Quote
Old 10-30-2013, 05:15 AM   #95
jararak
My Ride: e39 530d
ok, but than there is no option to power it off and check for example board compter or navigation?
Old 10-30-2013, 05:20 AM   #96
Davew
Ops board has a built in switch for this. It is very well thought out and executed imo
Old 10-30-2013, 06:27 AM   #97
PeteAU
My Ride: 330i
For an M3 owner, $100 is just pocket change isn't it?
Old 10-30-2013, 09:33 AM   #98
blakxr
My Ride: 2001 325i
Pity I only have the business class head unit
blakxr is offline   Reply With Quote
Old 10-30-2013, 04:09 PM   #99
E46 Coupe
E46 Coupe's Avatar
Old 10-31-2013, 03:24 AM   #100
94vtirozguy
My Ride: 330 ci convertible
I am very interested as well. I also am in the local area......even with supplied PI I am interested saves us stuffing around even more.
has there been a thought about digital radio integration as well ?
94vtirozguy is offline   Reply With Quote
Rate This Thread
