Old 08-25-2012, 07:53 AM   #1
xozzie1x
My Ride: 2003 325i
No Power...sometimes..
I have a high mileage 03 325i. I'm experiencing a very temperamental problem with power...as in..can't get the car to go up a hill with out putting my pedal to the floor.
Initially I thought it was just a tired engine with compression issues, however this appears to be a little too infrequent for it to be that. Yesterday, I drove a 80 mile round trip commute to work..no problem. Got up this morning to bring it to get coffee.. I thought I was going to have to push it.
New MAF sensor, new smog pump check valve, new oil water separator hose, new spark plugs. Got a new car on the way in 4-6 weeks, so trying to fix this as cheap as possible so I don't have to get a rental.
Thanks!
xozzie1x is offline   Reply With Quote
Old 08-25-2012, 08:55 AM   #2
bratliff
My Ride: 330i
Fuel pump and fuel filter maybe?
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 08-25-2012, 09:03 AM   #3
xozzie1x
My Ride: 2003 325i
Pump is relatively new. Filter I'd have to try and test somehow.
Old 08-25-2012, 09:38 AM   #4
shanneba
My Ride: 2003 330Ci
Run a bottle of Chevron Techron through in the next tank of gas to clean the injectors.
Measure the fuel pressure at the injector rail, it should be 50 psi +- 3 psi
Join BMWCCA
Old 08-25-2012, 09:51 AM   #5
BimmerJustin
I SHOP @ TURNER MOTORSPORT
My Ride: 02325CI,03MIN,06VW
Its not throwing a CEL with a loss of power?!?
Mini is caged..BMW is slammed...Touareg on 22's! Old pic!
BimmerJustin is offline   Reply With Quote
Old 08-25-2012, 09:52 AM   #6
xozzie1x
My Ride: 2003 325i
The only codes I'm getting are secondary air. Smog pump itself is working fine and replaced the check valve, but still code
Old 08-25-2012, 10:18 AM   #7
jasonbimmer
My Ride: 2001 BMW 330xi
vanos maybe?
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 08-25-2012, 12:50 PM   #8
xozzie1x
My Ride: 2003 325i
well..running 50 psi +/-
Old 08-25-2012, 05:12 PM   #9
xozzie1x
My Ride: 2003 325i
aaaaaaand the starter just let go..
Anyone want to buy a 2003 325i?
Old 08-25-2012, 05:16 PM   #10
JaaPee
My Ride: ///M
This happened to me and it turned out to be a crank sensor or something like that.
JaaPee is offline   Reply With Quote
Old 08-25-2012, 05:19 PM   #11
xozzie1x
My Ride: 2003 325i
I went out and rented a fuel gauge ..running at 50psi at the fuel rail. Put everything back together, figured I'd play around with the MAF to see if that had any bearing on engine response. Started it up a few times..with hesitation (It's been hesitating starting up the past few days..thought it would relevant to the engine trouble I've been having) Now I just hear a *click* with no turn over whatso ever.
