Ball joint, or Tie rod? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-25-2012, 08:51 AM   #1
Jagean
My Ride: 2001 BMW 325i
2001 325i auto 85k
My passenger wheel shudders while driving. I jacked the car up last night to do brakes, along with the "wiggle test" for the tires. I noticed I need to replace both CAB, but on the passenger side the tire (while on jack stands) wiggles when putting force on 3 and 9 o clock. I checked the tie rod, it seemed tight as I wiggled away, but the bolt for the Ball Joint under the brake had ALOT of play (would not tighten any more either). I was under the impression that ball ball joints made the wheel wiggle at 12 and 6 o clock and not 3 and 9. Any thoughts?
Jagean is offline   Reply With Quote
Old 08-25-2012, 09:04 AM   #2
maurer
My Ride: 04 Coupe
You should replace both left and right CAB's first and then determine if you must replace anything else.
maurer is offline   Reply With Quote
Old 08-25-2012, 09:08 AM   #3
lmr2wil
My Ride: '00 328Ci
The ball joint bolt should NOT wiggle. Does it not tighten even while stabilizing the stud with a hex key? I would determine whether or not you want to replace the control arm itself before you tackle the CAB's. If you put on new CAB's and decide after that the control arm needs to be replaced, you will likely need a second set of new bushings - which seems to me to be a waste of money.
Luke
lmr2wil is offline   Reply With Quote
Old 08-25-2012, 09:19 AM   #4
Jagean
I figured I would do the whole CA with bushing at the same time if that seemed to be majority vote. I am just confused with the movement that is happening, motor/electronic, I don't typically have to many issues, but I'm new to the world of suspension. Thank you for speedy responses so far.
Old 08-25-2012, 12:31 PM   #5
sfcjetjr
My Ride: 2002 BMW 325i
How many miles?
Most likely culprit.... CAB. Do both and use poly here not rubber. Put light lube on ends of CAB's to make install easier plus eliminate chance of creaks or squeaks. While your at it you should replace the swaybar bushings with poly and light greasing on inside that contacts the bar. Front and rear. Very inexpensive to do for a problem that will come. If only bushings don't do it then move to the entire arm. Replacing CA after the bushings will have very little effect on the cab bushings over a short period of diagnostic driving.
sfcjetjr is offline   Reply With Quote
Old 08-25-2012, 01:55 PM   #6
doggy
My Ride: 330ise
doggy is offline   Reply With Quote
Old 08-25-2012, 02:33 PM   #7
Jagean
That video pretty much looks like what mine is doing (mine sounds worse ), granted I was looking from the top, down. So... Ball joint, which means Control arm, and bushings. Thanks guys!
Old 08-25-2012, 02:58 PM   #8
doggy
My Ride: 330ise
i recommend meyle hd control arm + meyle HD bushes + check your alignment after you replaced those bits
Old 08-25-2012, 07:43 PM   #9
Jagean
I see that melye hd are highly recommended, and I have new tires to go on, so I was going to do an alignment also. I just wanted to get the suspension issue out of the way before putting new tires on. Thanks again
Old 08-26-2012, 01:40 AM   #10
MJLavelle
My Ride: 2001 BMW 330ci
Check the link below. $339 a set, and free shipping. You may find them a bit cheaper, but not with free shipping. Also, shipping costs for these are high, because they weigh quite a bit. Believe me, I have shopped around a LOT.
http://www.oembimmerparts.com/produc...758623my-2.htm
Old 08-26-2012, 06:33 AM   #11
Jagean
I have to pay for speedy shipping, but great find, about 52 dollars cheaper than I found (speed shipping was cheaper also ), Thank you!
Old 08-26-2012, 12:33 PM   #12
ryannel2003
My Ride: '04 Cadillac Deville
http://www.bmaparts.com/index.php
Use code specE30. Price is $299 shipped.
ryannel2003 is offline   Reply With Quote
Old 08-26-2012, 12:54 PM   #13
Jagean
If I didn't need to have them installed by next weekend I would go with them, 3 day shipping makes it the same price that I just paid. Good looking out though!
Old 08-26-2012, 12:55 PM   #14
ryannel2003
No problem man. I'm about to order a set for my 323. Let me know how your install goes!
Old 08-26-2012, 01:06 PM   #15
Jagean
I will, it does not look very hard, but you know how that goes sometimes.
Old 09-01-2012, 06:41 AM   #16
Jagean
I can go into details if you need, but for the low down:
Took 5 hours total for both sides, with no trips to the store.
My passenger ball joint was BAD, and thus came off easy.
Everything about the driver side was a PITA.
No alignment needed, and I can't believe this is what a BMW is supposed to feel like.
http://www.oembimmerparts.com/produc...758623my-2.htm (thanks MJLavelle) cost for 2-3 day shipping was $10, and it came literally overnight
Old 09-01-2012, 08:29 AM   #17
ryannel2003
That's great! I'm going to have to get an alignment for my car because it's been off for awhile and it's eating up my tires. There hasn't been a point until now to get one because I know that I needed the CAB and ball joints. My are waiting for install and it should be happening tomorrow with my new tires.
Old 09-01-2012, 08:47 AM   #18
Jagean
My alignment was WAY right, and after this and new tires, I didn't end up needing an alignment. Maybe you can get lucky also.
Old 09-01-2012, 11:39 AM   #19
doggy
My Ride: 330ise
jagean - did you take it to alignment shop and was told it didnt need alignment?
i think you should measure your toe - mine was way off changing to meyle hd
you will need to measure on level ground, straight steering wheel and tape measure at same height for accurate reading
Old 09-02-2012, 02:14 PM   #20
ryannel2003
Just installed mine today and what a difference!!! Car doesn't follow ruts in the road, crosswinds do nothing, and it feels more stable going around corners. I did get it aligned just to be safe. Car drives and feels like new.
