Old 08-25-2012, 09:34 PM   #1
edz2003
My Ride: 2003 325ci
Average MPG??
Hi everyone,
My MPG has been lurking around 18.8 and used to be at least 20! What could be causing this? Checked my tire pressure and have some idle issues which should be fixed once I clean my ICV? Any idea how I can get it Back up to i guess normal which should be around 25mpg? Thanks
edz2003 is offline   Reply With Quote
Old 08-25-2012, 09:43 PM   #2
tock172
My Ride: '12 135i DCT
O2 sensors and VANOS come to mind. What's your current mileage?
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 08-26-2012, 12:56 AM   #3
edz2003
My Ride: 2003 325ci
So done the vanos and not getting a check enginee light for o2's!! Got 113k miles 2003 e46 coupe
Old 08-26-2012, 02:08 AM   #4
katu
My Ride: '04 330ci ZHP
113k miles, do you have any leaks/holes in your intake boots?
katu is offline   Reply With Quote
Old 08-26-2012, 02:09 AM   #5
B_Cyrus
Banned User
My Ride: Malfouf
Is this freeway mileage or around town?
B_Cyrus is offline   Reply With Quote
Old 08-26-2012, 03:46 AM   #6
edz2003
My Ride: 2003 325ci
The boots Was replaced 2 yrs. Ago and in its both highway and city miles
Old 08-26-2012, 03:57 AM   #7
swordsman11868
My Ride: 2003 325i
118k miles. 30 hwy. 21 city. About 24 mixed city/hwy.
Change your air filter if your mileage goes down. Or clean/oil your K&N if you have that.
.02
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 08-26-2012, 07:30 AM   #8
Jagean
My Ride: 2001 BMW 325i
I was getting 22 hwy/city mile, and that was before I found the oil leak and changed out the oe spark plugs and Valve cover (oil on the plugs). I also cleaned the ICV and TB. Hope mine goes up, we'll find out this week.
When you clean your ICV take the time to clean your Throttle body also. After your ICV is out, its only four bolts, and an electronic clip. The front of mine was not bad, but the back side was covered in grime to the point it was restricting movement. There is a orange rubber gasket on the back, make sure that is in good shape also.
Jagean is offline   Reply With Quote
Old 08-26-2012, 07:44 AM   #9
scrace
My Ride: 03.5 M3
Clean TB, DISA, and MAF sensor.
Replace air filter and spark plugs for starters.
I was getting 32 highway in my 325 but it was fully maintained.
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 08-26-2012, 08:40 AM   #10
Jagean
32 mpg! nice, now I have something to shoot for. Before fixing stuff on our new car I was worried b/c the Bimmer got less mpg than my Camaro.
Old 08-26-2012, 08:50 AM   #11
aikmanson
My Ride: E30
119k 323ci 5 speed. 28 town / 34-35 highway. Maintenance is up to date and just replaced my fuel filter which gave me an extra 1.5 all around.
These are my average numbers to be honest, even with some spirited driving and high shifts.
1990 BMW 325is - Stroker Build
2010 MINI Cooper S
1995 Saab 900 SE - JZW Stage 4
aikmanson is offline   Reply With Quote
Old 08-26-2012, 09:08 AM   #12
sammk
My Ride: Bone-stock E92
Well.. Depends on whether we're talking about the OBC display or calculated based on miles and fuel fills.. The OBC usually over-predicts by 2-3 mpg.. Calculated, I used to get around 21-22 mpg city, 30-31 mpg hwy and around 23-24 mixed... A little more in the summer, a little less in the winter. '04 325i with 5-speed manual and around 80k..
E92 convert. BMW Fanatic.
sammk is offline   Reply With Quote
Old 08-26-2012, 09:21 AM   #13
Jagean
My digital read outs don't actually work correctly. All I can see is mileage, time, and trip. I can't reset or anything, so I use the old method of, fill to the first click, drive, fill to first click, divide mileage by gallons.
/Sorry about thread jack?
Old 08-26-2012, 09:28 AM   #14
edz2003
My Ride: 2003 325ci
It's very difficult to located where I might be experiencing this as i've done numerous things and has not improved it! My next move is cleaning the ICV and see where that takes me I guess but my ride drives like a tank (slow and heavy)
Old 08-26-2012, 09:29 AM   #15
sammk
Agreed, that's about as accurate as it gets.. And when you average that out for several tankfuls in a row, you get a good measure of the true mpg...
Old 08-26-2012, 10:32 AM   #16
notsoworried
My Ride: 325i
Using this same method I clock 23mpg city 25 regular hwy. I took the tollway out of Austin back to San Antonio cruised about 90ish and clocked 26mpg.
notsoworried is offline   Reply With Quote
Old 08-26-2012, 11:15 AM   #17
Jagean
Driving like a tank is not good, imo (for as little as it counts) it seems like your not getting enough of something: spark, gas, air (those are the easy ones to check). Make a check list, and take your time, also, check your codes anyways. My light doesn't come on, but it will still store codes. I just figured my light is burnt out.
also Edz, how long has this been going on?
Old 08-26-2012, 01:36 PM   #18
tock172
Replace them anyway. They're worn out.
Old 08-26-2012, 02:31 PM   #19
Goughie
My Ride: 330d Sport Touring
<<<<<<<<<<<<<<<<< comfortably gets 36mpg
http://i38.tinypic.com/oif03r.png
Sig is a BlownE30M3 production!
"The protection of views purely on religious grounds cannot be justified. It is not only an irrational idea, but it is also divisive, capricious and arbitrary" - Lord Justice Laws, UK 29/04/2010
Goughie is offline   Reply With Quote
Old 08-26-2012, 02:58 PM   #20
BBBoy323i
My Ride: 01' 325ci
Dude teach me your ways. I get 16mpg city and 25 ish on highways. Gonna do a big tune up soon do hopefully that helps
BBBoy323i is offline   Reply With Quote
