P0171 and P0174 help - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-26-2012, 06:08 PM   #1
dusty132
My Ride: 2002 330ci
Alright so I got these two dreaded lean codes on my car. I have already replaced both intake boots and my fuel filter a while ago. I also tried cleaning my MAF with cleaner. I still have a slight whistle from somewhere but I can not pinpoint where it is. Please let me know any ideas.
dusty132 is offline   Reply With Quote
Old 08-26-2012, 06:12 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Check the DISA
Old 08-26-2012, 07:34 PM   #3
cityjohn
My Ride: 2001 M3
or possible vacuum leak
cityjohn is offline   Reply With Quote
Old 08-26-2012, 11:26 PM   #4
JL-330-
My Ride: 01 330CI 5SPEED
Get a can on brake clean and spray intake and all surrounding vacuum hoses and disa valve, if idle changes then you have a intake leak and or vacuum leak, also remove disa valve hold magnet to metal pin in the end and see if the in is held in place, also with car runing slighty open
oil cap dont pull it off just slightly lift it u should feel vacuum pulling the cap back down, if extreme vacuum is felt then you probably need a crankcase vent valve do not install the updated foam insulated one on the e46 as this is not needed but do replace the oil dipstick with the up dated one., long story short its most likely the crankcase vent valve
JL-330- is offline   Reply With Quote
Old 08-26-2012, 11:28 PM   #5
JL-330-
Also check for leaking valve cover gasket as this could in rare cases set these faults as well
Old 09-20-2012, 01:11 AM   #6
taburki1s
My Ride: 2003 BMW 330i
Any updates OP?
taburki1s is offline   Reply With Quote
Old 09-20-2012, 07:43 AM   #7
dusty132
My Ride: 2002 330ci
I had fixed the problem by changing my disa out thanks for all the help
Old 09-25-2012, 08:19 PM   #8
Bandit4077
My Ride: 330i SuperVeloce
was it just the seal, or did it shatter completely? win for jake!
Some say, that inside his helmet, there is another helmet. All we know is...
Check out my interior: http://forum.e46fanatics.com/showthread.php?t=1055263
Bandit4077 is offline   Reply With Quote
Old 09-26-2012, 11:05 AM   #9
dusty132
My Ride: 2002 330ci
The seal was destroied
p0171, p0174
