Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Parting Out
Parting Out
Parting out your car? Post your entire list of BMW parts for sale in one forum. Single items should be posted in one of the other classified forums.
Old 09-04-2012, 07:34 AM   #21
Chad44
My Ride: 03' Imola 330i ZHP
Originally Posted by MR27122 View Post
Sunroof. Teeth on mine r fried & I have the pwr pulled. Probably just need the track assembly & not glass, but if it has to be be w/ glass no prob.
I'll sell you the track alone, no problem.
Chad44 is offline   Reply With Quote
Old 09-04-2012, 02:50 PM   #22
trizzuth
My Ride: 231k, 16yr old B3AST
Chad, do you happen to have the passenger side horn? Might be destroyed based on the impact of the accident, but I figured I'd check anyways..
trizzuth is offline   Reply With Quote
Old 09-04-2012, 07:42 PM   #23
Chad44
Definitely no horn, sorry man I just can't seem to get you anything you want!
Old 09-05-2012, 11:22 AM   #24
trizzuth
Springs and shocks gone now too?
Old 09-05-2012, 10:42 PM   #25
vypercat
My Ride: 2004 330i ZHP
Hi just reading the specs, it doesn't look like your car came with the winter package but just in case:
Do you have the headlight washers on your car? I'm looking for the cover piece that popped out from my driver side. 61677066847
#9 in this pic
http://www.realoem.com/bmw/diagrams/d/o/134.png
Thanks,
Chris
vypercat is offline   Reply With Quote
Old 09-06-2012, 07:29 PM   #26
Chad44
No, I'm saving those for you!
Old 09-06-2012, 07:30 PM   #27
Chad44
#9 in this pic
Thanks,
Chris
You're correct, no winter package! Sorry
Old 09-07-2012, 02:50 AM   #28
e40Blitz
My Ride: 2000 328ci
any word on that foglight harness?..any side will do its 9006 correct?
e40Blitz is offline   Reply With Quote
Old 09-07-2012, 07:10 AM   #29
Chad44
The fog light plugs are there, but the harness is integrated with the main harness and each side just joins all the other cables and heads into the firewall... I could cut the connectors off the harness if that's all you need, otherwise please specify what your intended use is so I can best get you what you need.
Old 09-10-2012, 10:37 PM   #30
Saintluk2
My Ride: 2000 323i sedan
do you still have the driver's side exterior shadowline trim that runs from the bottom of the A pillar to the bottom of the B pillar ?
Saintluk2 is offline   Reply With Quote
Old 09-10-2012, 11:45 PM   #31
Hornung418
My Ride: '04 MB ZHP
Chaddy, did you also give the engine harness/DME to "the guy?"
Looking for those, the e-pedal and EWS w/ all four lock cores + key.
Thanks, bro.
Hornung418 is offline   Reply With Quote
Old 09-11-2012, 12:05 AM   #32
SteadyMobbin
My Ride: ImolaZHP 6spd M/T
Radiator damaged? I need the mounting plate for the expansion tank
SteadyMobbin is offline   Reply With Quote
Old 09-11-2012, 10:42 PM   #33
Chad44
i have one of the trim pieces, but am not sure which side.. ill have to check and get back to you.
Old 09-11-2012, 10:48 PM   #34
Chad44
Thanks, bro.
they took the engine harness and dme... sorry man! I have another member that is interested in the accelerator pedal but is waiting for me to get it pulled out for him. As far as the locks and ews- I have all those, the trunk, column and key are easy but how do i take the cylinder from the doors?
Old 09-11-2012, 10:50 PM   #35
Chad44
i sold the expansion tank (with bracket attached) last friday... ill ask the guy if he is using the bracket or not.
Old 09-11-2012, 10:52 PM   #36
Sean McClellan
My Ride: 2004 325xi
Do you still have the drivers side mirror?
Sean McClellan is offline   Reply With Quote
Old 09-11-2012, 11:31 PM   #37
Chad44
i do, but the outside trim panel is broken off...I'll have to check on the condition mechanically if you are still interested.
Old 09-11-2012, 11:34 PM   #38
saphblack
My Ride: 2002 330i
I need the shark fin without the wiring just for the look and rear panel speaker...how much you want for them? I live in houston thanks
Sent from my SGH-T999 using Bimmer App
saphblack is offline   Reply With Quote
Old 09-11-2012, 11:35 PM   #39
Chad44
tell me what it is that you need... do you jut need the plug and 2 feet of harness? or do you need the harness back further? If all you need is the plug and a little wire, I could have it in the mail tomorrow. If you need more, I'll have to figure out what you need and get it pulled which could take a couple days. im not sure on the foglight bulb type.
Old 09-11-2012, 11:37 PM   #40
Chad44
The shark fin is happily mounted in it new home on my car, and you want the woofer in the back window deck, correct? I have non HK
