Old 08-26-2012, 09:09 PM   #1
PANDAemic
My Ride: 2000 323i Sedan
Windshield weather stripping
So the weather stripping that lines the winshield of my car is cracked and crumbled into pieces. It's not as bad as it might sound but I was windering if this could harm my car in any way if it happens to rain or if I wash my car.
I have washed my car a few times and I noticed some electrical problems like my radio shutting off but I'm not 100% sure if thats the cause or not. I'll attatch a pic of what I'm talking about.
If it is harmful, how would I go about fixing it or replacing the stripping and how much would it cost?
PANDAemic is offline   Reply With Quote
Old 08-26-2012, 09:10 PM   #2
stevenluczynski
My Ride: Is Steel Blue
its called a windshield cowel, 40 bucks to replace.
stevenluczynski is online now   Reply With Quote
Old 08-26-2012, 09:13 PM   #3
PANDAemic
Is this something I should be able to do at home or should I hire somebody to do it?
I'd like to say I have moderate knowledge about cars but I would never touch anything that has to do with electricals or engine.
Old 08-26-2012, 10:20 PM   #4
John in VA
My Ride: 328i/325xi
Actually, it's the cowl. The part may be $40, but you'll not find a shop to replace it for that! Do it yourself, with the help of this:
http://forum.e46fanatics.com/showthr...highlight=cowl
Find the proper part numbers for your model here:
http://realoem.com/bmw/select.do?kin...ies=E46&arch=0
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 09-19-2012, 06:40 PM   #5
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
I have the same problem with my windshield weather stripping. You live southern? I do. The heat messes with the trim as well. As for your radio shutting off, do this, turn your radio on, and then flash your high beams, does it turn off? or pause playback? I had the same problem this morning, but the battery was just low on charge.
aahmed2016 is offline   Reply With Quote
Old 09-19-2012, 06:51 PM   #6
PANDAemic
The issue with my radio is a hole different matter I learned. I drive manual so I learned that if I get a bad start my electricals start to act up.
