Idling RPM irregular and hesitate to go - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-29-2012, 02:17 AM   #1
mcygan67
My Ride: E46 318i N42 Auto
Hello everyone,
I am trying to determine possible causes with my E46 318i N42. It is giving the following symptoms:
I just got the oil sump gasket one of the oil separator hose replaced.
1. Occasionally (seems more frequent of late) the idling RPM (about 700rpm) is slightly irregular. Most of the time after coming to a stop at lights but sometimes just after start, whether cold or warm engine. It feels like the idling dropped and then picked up again slightly repeatedly.
2. When the above happened, the car hesitated to go when the accelerator is depressed. Once the RPM is above (i think) 1500, power is back and the drive is smooth.
3. I've also noticed that the above 2 symptoms are not likely to occur if the air-cond is switched on (which brings the idling rpm to above 900, closer to 1000).
4. On 2 separate occasions, when driving off after a cold start, the engine started knocking and significant lost of power was experienced. It felt like either the engine was misfiring or have lost at least 1 cylinder. This symptom goes away after turning the vehicle off and start again on both occasions.
Base on the above, I'm wondering if this is the start of a serious problem?
Thanks for any help.
Regards.
mcygan67 is offline   Reply With Quote
Old 08-30-2012, 11:54 PM   #2
94583
My Ride: E39
Based on your symptoms above have you checked for unmetered air leaks? aka vacuum leaks. If none found I would make sure that the idle control valve is not sticking/clogged.
Good Luck!
94583 is offline   Reply With Quote
Old 08-31-2012, 01:12 AM   #3
mcygan67
Hi 94583,
I am not a mechanic and don't know how to check for unmetered air leaks. Do you know of any article/diy? Also, how can I tell if the idle control valve is not sticking?
Thanks very much.
Sponsored Links
Advertisement
Old 08-31-2012, 03:04 AM   #4
mcygan67
Additional information:
Just changed the set of spark plugs. Inspected all the old plugs and they are all fine with no sign of oil. However, I am using like 1L every 500km.
I've recently (6 weeks ago) had the sump gasket replaced as it was leaking. After that, I have not noticed any leak as the bottom of the car is clean. No sign of oil.
Any idea?
Old 08-31-2012, 03:07 AM   #5
mkodama
mkodama's Avatar
Vacuum leak.
Old 08-31-2012, 12:32 PM   #6
Viktimize
My Ride: 2002 325i,2003 330ci
If you already had to replace one of your CCV hoses, good chance the others are on the verge or have a crack that is big enough to create a vacuum leak. Assuming you're over 60-100kmi, I would replace all the CCV and hoses, air intake tubes, clean ICV, etc. All that basic maintenance stuff that should be done anyway. Good chance your problem will be solved after that.
Viktimize is offline   Reply With Quote
Old 08-31-2012, 08:34 PM   #7
mcygan67
Vacuum leak.
Thanks for the links. I have a copy of TIS but it is not very descriptive and because I am not a mechanic, I find it hard to understand. That is why I am looking for DIYs from other owners.
Thanks for the information. I will attempt to locate DIYs that show me how all these can be done.
Will post back the result but this may take awhile.
Old 09-05-2012, 07:50 PM   #8
mcygan67
Update:
- Cleaned the MAF but did not notice any improvement.
- More research from the Net tells me that my 318i E46 N42 engine does not have ICV.
- Can't find any DIY on replacing the CCV/PCV/Oil Seperator for my car although there are plenty for other engine types.
- I have a copy of TIS but can't find any information about replacing CCV/PCV/Oil Seperator. The oil seperator is mentioned at various places like checking crank case pressure and the intake manifold.
Anyone knows of any DIY for the 4 cylinder N42? Please help. Thanks.
Old 08-31-2015, 07:13 AM   #9
letkuteb
My Ride: E46 316TI 2002
I hope it helps
letkuteb is offline   Reply With Quote
Old 02-09-2017, 10:33 PM   #10
lhuy2733
My Ride: 01 E46 M3
Hi,
Old thread revive sorry.
If you are still around how did you go with this?
Easiest and cheapest fix would be to check the hoses?
I am suffering the same symptoms.
lhuy2733 is offline   Reply With Quote
e46, engine, idling, n42
