///M3 Forum
The BMW E46 ///M3 is the M version E46 and puts out an amazing 333 HP and 262 lb-ft of torque at stock specs! There are an amazing amount of modifications for both the coupe and convertible models so read up and get started modifying your cars today! |
Rating:
Display Modes |
#1 |
SMG Tips and Tricks
If you need troubleshooting, go here.
This thread is only for tips and tricks to activate features of the SMGII transmission. If you have more to add, by all means go ahead. Please try to keep the same type of formatting as below. I know a few other tricks that I will add over time, but this is a start. Disclaimer: All information on this thread is publicly sourced and is not guaranteed or to be held liable in any way. In other words, if you break your sh** it isn't our fault. Soft Reset: Confirmed: Travel at 40+ MPH, move the selector lever to "N", pull back on both paddles for 8-10 seconds, move the selector lever back to "D". Winter Mode: Confirmed: Put car in "D", Traction control "On", Sports Mode "Off", Drive Logic at level 1. Warning: This will cause premature clutch wear as the car attempts to start off in 2nd gear. Hill Hold: Confirmed: While on a hill and in "S" mode, pull back and hold the "-" paddle until RPM's elevate. This will partially engage the clutch and hold you on the hill. Warning: Again, pre-mature clutch wear. If you're not moving within 1-2 seconds of using this, you shouldn't be using it. Emergency Acceleration Mode: Confirmed: "D" Mode "A" on some models. This is just a special mode BMW put in as a "safety feature" Basically just mat the gas. Traction control and clutch engagement will operate in such a way that the vehicle accelerates at its optimum ability for the given conditions. |
#2 | |
#3 |
Yes. The car starts off in second gear and has a longer engagement time to keep the wheels from slipping. It would be the same result as if you drove any manual car and slipped 2nd every time you took off. Unfortunately this will cause premature wearing of the clutch - mind you it's not drastic, but it does exist. In my honest opinion, the benefits of Winter Mode are worth it.
#4 | |
Mister TechnoMeister
#5 |
i think its usefull, i dont need to use it since im in miami though
![]() Long Nights and Sandy Beaches |
#6 |
launch control: turn off traction control, put car in manual mode, sport on, smg in mode 6, hold shifter in the "-" position and hold accelerator down, rpms jump and fluctuate from 1500-2000 rpm. let go of shifter and car launches
#7 | ||
Both are definitely cool tips though, use them both quite often - so far no issues have arisen with the clutch (80k and going strong)
"! First rule of Italian driving, that which is in your mirror is not important !"
#8 |
I say 8-10 seconds because normally people are freaking out and count too fast but you are 100% correct on both accounts.
#9 | |
Honestly, unless I'm losing it, you don't even have to be at 40+ MPH. I prefer to do my soft resets coasting to a stop that way it can start all over again reengaging the clutch in 1st instead of finding a gear at a given MPH. In regards to the Uphill Assist,, or "hill hold" as you've called it.. You can easily tap the paddle again to disengage if you don't intend on moving within 1-2 seconds. It's nice for me because I have a right turn on red on my way to work and sometimes I can use it, others I have to disengage because someone will be flying down the street when I think I have an opening. |
#10 |
Sport mode on or off will not affect LC.
![]() |Carbon Fiber Intake|AA GEN3|AC Strut Brace|Eibach/Koni's| |Victory UDP's|HPF Sub Frame Plates| PF Subframe Bushings|Rtab Limiters| |
#11 |
What is this... last emergency acceleration? D or A mode?
04 Jet Black SMG - NAV
Cinnamon Sonic Tuning Spacers 15mm \\// More to come...:shifty: Valentine V1 BMC filter Full real carbon trim to include seat backs and paddles Scorza Euro Header+Cat !*!!* All EURO parts : m3e46freak@yahoo.com !!**!*! ![]() |
#12 | |
Modded ///Member
![]() ** Too much for a signature ** Instagram @ j_cerna |
| Tags |
| launch, modes, reset, smg, smgii |
