Old 08-30-2012, 12:59 AM   #1
MasterNater
My Ride: '03 Silver Vert M3
Agency Power V2 Exhaust or Magnaflow Catback exhaust?
I'm looking to get an exhaust for my '03 M3 Vert. I haven't done any major modifications to it. I'm going to install cold air intake this weekend but I'm also looking to get more horsepower and a better sound by upgrading my exhaust.
Which would you get, and why?
Thanks!
MasterNater is offline   Reply With Quote
Old 09-21-2012, 02:07 PM   #2
ModBargains
ModBargains's Avatar
My Ride: M3
Are you considering any other systems besides those two? We have had great luck and amazing feedback from the Rogue Engineering "El Diablo" exhaust! Its got a super clean look with a perfect fit and great tone. You even have the option of adding the Rasp Pipes and the X-Pipe if you want to complete the cat-back exhaust. Its something to consider in addition to the Agency Power or Magnaflow. If you have any other questions, im here to help!
Rogue Engineering E46 M3 Exhaust Features
The Rogue Engineering El Diablo is made to fit exactly like factory. Improved, updated specs!
  • Weighs only 30 lbs., 26 lbs. lighter than the factory muffler! (factory is 56 lbs.)
  • 100% T-304 stainless steel construction and internals, 10% larger tubing than previous version! New!
  • Fully mandrel bent tubing, no crimps or flattened areas
  • Mil-finished pipes and muffler, mirror polished stainless steel quad 80mm Club Sport tips! New!
  • Full TIG welded construction, no lock seams or pinch welds.
  • Rogue Engineering logo tastefully stamped in the body of the muffler
  • Flow-through design does not create muffler "hot spots" found on chambered mufflers
  • Optimized tubing sizes and minimized bends maintain exhaust velocity without compromising necessary backpressure
  • Deep, throaty tone, without the drone.
  • Easy to install (compared to other systems in the market)
Blake Brunner|blake@ModBargains.com|(714) 582-3330 ext. 8011
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels | BMW Intake
Hours
Check out our Blog for updates!
ModBargains is offline   Reply With Quote
