Old 08-30-2012, 03:03 PM   #1
coach94
My Ride: 2001 330ci
A/C works on an off help!
I have a 2001 330ci and my a/c heat etc has a habit of deciding not to work sometimes. It wont blow any air when it doesnt work including the defogger. Does anyone have any ideas why this happens? it suddenly just stops working and days later it will randomly start again i find it quite odd.
coach94 is offline   Reply With Quote
Old 08-30-2012, 03:09 PM   #2
Teddy7
My Ride: slides
Almost textbook example of a faulty FSR (final stage resistor). Swap out with a new one and you should be good to go. The forum is littered with info about this. When it's working, does your a/c still blow normal as far as the set temperatures you want blowing out of the vents?
Teddy7 is offline   Reply With Quote
Old 08-30-2012, 03:09 PM   #3
jasonbimmer
My Ride: 2001 BMW 330xi
Final Stage Resistor
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 08-30-2012, 03:23 PM   #4
coach94
My Ride: 2001 330ci
I mean it does for the most part but it does seem like the cold air isnt as cold as it used to be before this problem arised. How much does this FSR's usually go for?
Old 08-31-2012, 11:35 AM   #5
Teddy7
My Ride: slides
[I mean it does for the most part but it does seem like the cold air isnt as cold as it used to be before this problem arised. How much does this FSR's usually go for?[/QUOTE]
Well in that case I wouldn't worry about it too much. The less cool air could be do to a loss in charge. Simple fix. As far as the FSR. Here you go> http://www.ebay.com/itm/BMW-Final-St...b912d9&vxp=mtr
Let me know if you need any more help with A/C stuff after the replacement of the FSR.
