Old 08-30-2012, 06:27 PM   #1
Caden
My Ride: 2012 Genesis 5.0
Power Steering Whine
My fluid is low, I have a leaking hose. I'm replacing it today, but I was curious if the whine was anything to worry about? It's a really high pitch whine that happens when I turn the wheel just a little bit and continues to whine until I bring the wheel back to center. Is my pump bad or just need to replace the hose and top off with Dexron?
Caden is offline   Reply With Quote
Old 08-30-2012, 07:14 PM   #2
zander271
My Ride: 6spd ZHP/5sp XI
Well I would def get the PS level to what it should be. My PS pump whined just before it gave out. Besides the whine do you noticed that it is harder to turn the wheel when going slow? Not hard like the pump is dead but basicly not easy and slow turning like it should be?
Figure out the exact production date of your car
Get a LUK PS pump
LF - 20 Production date up to 09/2001 - Part # 32416760036
LF - 30 Production date from 06/2000-12/2000 - Part # 32411094965
LF- 30 Production date from 09/2001 to 09/2002 - Part # 32416756582
BMAparts.com sells these for $266 bucks, which I wish I had known about when I did the PS pump on my car. I spent $400 dollors from a local place.
Also don't get some cheap knock off to save $100.00
Replace your reservoir and all of your hoses....I'm at work. When I get home I can try and figure out all of the parts you should replace while you are in there.
BMW Reservoir - part #32416851217
BMW PS Cap seal - Part # 32411128333 ( I can't remember if this came with the res)
Hoses
PS Steering Feed Line
LF - 30 Production Date 06/2000 - 12/2000 - 32416764725
LF - 20 Production Date 09/1999 - 09/2001 and for production dates from 09/2002 - Part # 32416774215
From reservoir to power steering pump
Part # 32411095526
Part # 32416750155
PS return hose
Part # 32416796367
I can't remember how many clams I replaced because the BMW ones pissed me off anyone?
