Old 08-30-2012, 06:25 PM   #1
Harrison1972
My Ride: 2001 330xi
Question OBC Issues
Hey Everyone,
My first thread so here it goes:
Had my alternator replaced a few months ago by an indy shop, and started having problems with the OBC. Would only show outside temp (and was accurate), but I couldn't scroll through anything else or change the time.
Just had my GM5 repaired, so had to disconnect the battery again, and after hooking everything back up, my OBC reads only dashes (--:--) and I can't get it to do anything else.
I've found the OBC test pages in my Bently manual, but was hoping for a little input before I start messing around with things.
Anyone ever seen this or know what's going on???
Thanks so much!!
Harrison1972 is offline   Reply With Quote
Old 08-30-2012, 10:41 PM   #2
94583
My Ride: E39
based on the dashes you have drawn, have you set the clock?
94583 is offline   Reply With Quote
Old 09-06-2012, 06:06 PM   #3
Harrison1972
My Ride: 2001 330xi
OK, I was able to get the clock to reset so now it shows the time, but it still won't toggle through any of the other functions, i.e. mpg, average speed, miles to go, outside temp, etc..
Any insight???
Old 09-06-2012, 06:12 PM   #4
kd7iwp
My Ride: 2001 325i
Hmmmm, sounds to me as if the car has forgot that it's coded for obc. My 325i didn't come with OBC originally and only had the --:-- (or the time once I set it). Then when I bought an OBC stalk and re-coded the car for it I had all the other options. If you have access to DIS, PA Soft or some other software to do it, you can recode it. Personally I used DIS v44 to do it.
kd7iwp is offline   Reply With Quote
Old 09-06-2012, 09:28 PM   #5
FenderGuy05
My Ride: 2002 BMW 325i
^+1
Maybe have it recoded, using PA soft is the cheapest way that I can think of, that's how I added the OBC in my car.
FenderGuy05 is offline   Reply With Quote
