Old 08-31-2012, 11:35 AM   #1
cyberlando
My Ride: 2002 M3
AR20 exhaust welding question
how did you guys welded it in!
did you tig or mig weld it?
and if you did mig weld it what kind of wire did you use?
is the factory e46 m3 exhaust stainless steel?
how should i go about doing this?
Engine:
[] Euro Headers [] Euro Cats [] OEM Section 2 AR20[] B&B Exhaust [] AFE Stage 2
Interior:
[] Led Interior [] DICE Module [] Auxilary 3.5 jack [] 4 channel Amp with component speakers.....and more
Suspension/Handling:
[] KW V3 [] Eibach F&R Sways [] Vibratechnics Tranny mount [] UUC RTAB
[] Vibratechnics Motor Mount [] SSBL [] Turner Camber Plates
[] 90A Akg Subframe Bushings [] Akg Differential Bushings [] Subframe Renforcement
cyberlando is offline   Reply With Quote
Old 08-31-2012, 12:12 PM   #2
cposk
My Ride: 08' E90 M3
I mig welded mine. The bottom is with stainless wire, but my regulator was messed with and I ran through a large tank of gas in 5 minutes. So I went to using gasless wire (top). Stainless is definitely the way to go if you can.
The metal of the resonator is very thin, so I had to pool on the pipe and drag it onto the joint. It was the only way I could get good penetration on the pipe without burning through the AR20.
Oh and BTW, I have no formal welding training.
cposk is offline   Reply With Quote
Old 09-01-2012, 12:13 AM   #3
cyberlando
My Ride: 2002 M3
i think ar25 would have been easier to weld in if i thought about it first!
i have no stainless wire though
Engine:
Interior:
