Old 09-01-2012, 10:02 AM   #1
maurer
My Ride: 04 Coupe
Tire wear, but alignment is good
Both front tires are starting to cup on the outsides. The insides are normal. I have had a recent alignment and the car drives straight as an arrow. The car does have 108k miles, bought the car used about 10k miles ago so I'm assuming some suspension is in order. Front control arms, ball joints and bushings were replaced right after i bought it. Could it be something else I'm missing? If it is the struts, is there anything that goes along with them that I should replace as well?
maurer is offline   Reply With Quote
Old 09-01-2012, 10:26 AM   #2
bratliff
My Ride: 330i
It could be shocks. Also check your tire pressure and use the plate on the driver's door jamb to determine proper psi. Did you have the tires balanced when the car was aligned? Cupping tends to indicate the tire is bouncing which should be shocks or out of balance.
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 09-01-2012, 11:18 AM   #3
yetiinimolazhp
My Ride: E46 ZHP
If alignment is good, then I would suspect low psi in tires.
“Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.” (Winston Churchill)
yetiinimolazhp is offline   Reply With Quote
Old 09-01-2012, 11:40 AM   #4
jfoj
My Ride: 330CiC, M5, X5
Is is cupping or wear?
Cupping could be tire design and/or a suspension issue.
How many miles on the tires? Brand and model of tire?
Google the tire brand and model and it will tell you a lot if the tires are subject to strange wear, there will be many complaints on many models.
Old 09-01-2012, 12:07 PM   #5
doggy
My Ride: 330ise
just because your car goes straight doesnt mean alignment is good - do you have a printout of your alignment specs? excessive toe in or not enough camber will cause outer tire wear. what brand did you replace the control arms,tie rods and bushes with? if not meyle or lemforder then they are likely worn and need replacing and could also be responsible for outer tyre wear.
doggy is offline   Reply With Quote
Old 09-01-2012, 12:18 PM   #6
SweTurbo
Big Pimpin'
My Ride: 323i -98
If you have wear on both the inner and outer edge of the tire than the tire pressure is too low.
Old 09-01-2012, 12:24 PM   #7
shanneba
My Ride: 2003 330Ci
http://www.procarcare.com/includes/c...dtirewear.html
Cupping
Cups or scalloped dips appearing around the edge of the tread on one side or the other, almost always indicate worn (sometimes bent) suspension parts. Adjustment of wheel alignment alone will seldom cure the problem. Any worn component that connects the wheel to the car (ball joint, wheel bearing, shock absorber, springs, bushings, etc.) can cause this condition. Worn components should be replaced with new ones. The worn tire should be balanced and possibly moved to a different location on the car. Occasionally, wheels that are out of balance will wear like this, but wheel imbalance usually shows up as bald spots between the outside edges and center of the tread.
Join BMWCCA
Old 09-01-2012, 10:07 PM   #8
maurer
My Ride: 04 Coupe
If low psi in tires it would be wearing on both inner and outer
