Boost and Temp Gauge Install on ESS TS2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-19-2012, 06:30 PM   #1
AndyN
My Ride: ESS TS2 325ci
Arrow Boost and Temp Gauge Install on ESS TS2
Hi Guys,
I am installing the defi racer gauges on my ESS TS2 tomorrow morning. I am hooking the boost gauge up to one of the two vacuum hoses on the intake manifold. I am connecting the oil temp gauge through the Ruff oil filter cap. I have 3 questions;
1. Does it matter which of the two vacuum hoses I connect the boost too as they are both not in use?EGR or Exhaust Flap Actuator?
2. It is a RHD car. Is the only entry from under the hood to the cabin of the car through the ECU box and is this the route I should take?
3. Last and most important question is. I am using the ATI gauge holder (the mickey mouse ears holder!). Is there any particular power supply wire behind this that you guys normally hook gauges up to or should I just borrow a voltmeter off a friend and go crazy?
Thanks in advance..
AndyN is offline   Reply With Quote
Old 08-19-2012, 10:11 PM   #2
SweTurbo
Big Pimpin'
My Ride: 323i -98
Originally Posted by AndyN View Post
Hi Guys,
Thanks in advance..
1. I would go off the exhaust flap , dunno about the EGR vacuum but if it comes off the manifold both should be fine.
2. You have rubber grommets in the "drug bin" that you can run wires through
3. Personally i use the HU power wire , i run it to a relay and then from the relay(which feeds 12v from the jump point under the hood) to the gauges.
The iginition wires are just below where you install the ATi gauge holder so you should be able to tap the switched 12v there.
Personally i like to run things through relays
Old 08-20-2012, 11:30 PM   #3
lab rat
My Ride: '02 330iT
1. doesn't matter
2. both sides - ECU and drug bin have pass-thru
3. dunno
Because sleeper
Old 08-21-2012, 06:50 PM   #4
AndyN
Hey guys... Thanks for the response. I have them hooked up finally. They are hooked up throught the bin on the left hand side (when looking at the car from the front)
For the gauges I needed an ignition wire. a battery wire and a light up wire... Now when I took the cover off the steering wheel cover I found a few wires but all of them either used full battery power all the time or only when ignition...
So I went with the power from the ESS TS2 water pump as I knew that shut off when the car shuts off.. Every other connection stayed on when the car was tirned off....
Anyway I love it.. Although Irish Insurance is impossible....
Old 08-21-2012, 08:11 PM   #5
WALKD U
My Ride: Just Fast!
Pics of your boost and temp guage install?
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 09-04-2012, 06:11 PM   #6
BMANN405
My Ride: 2002 325ci
I have same supercharger kit on my car along with mickey mouse gauge pod. You can use either connection for boost gauge. Had my boost gauge and wideband air/fuel gauge installed by Turner Motorsports and they used the steering column to feed wires into cabin from engine compartment. Good Luck!
BMANN405 is offline   Reply With Quote
