Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 09-01-2012, 12:51 PM   #1
slo323ci
My Ride: 00 323ci
Best way to remove Shot it studs from concrete.
The previous owner shot in the studs into the concrete in the basement, what would be the best way to remove them? the 4" side is the side shot in, so worst case scenario I could just put new studs up the "correct" way, but it would make a pain running wires through with the old studs there.
slo323ci is offline   Reply With Quote
Old 09-01-2012, 12:57 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Sledge hammer if you can knock the stud from side to side to loosen it up. Monster pry bar a little at a time.
But, you know you can just drill through the studs...make holes through the studs at least 1 1/4 inch back from surface of wall...in the center of stud. You can easily fit a couple of wires in a 5/8" hole...make hole bigger if needed and keep it up from the floor....12-18" or so...some level comfortable to drill at.
See me in June!
dmax on Facebook
Mangofy your E46!
dmax is online now   Reply With Quote
Old 09-01-2012, 01:09 PM   #3
slo323ci
My Ride: 00 323ci
But what about the shot in nail? I shouldn't have any issues pulling the nail out right?
Old 09-01-2012, 01:14 PM   #4
dmax
dmax's Avatar
If I'm understanding you, you could lift up a stud with nails, right out of the concrete. They hold well, but concrete is pretty brittle, so a bit of force should pop them out...
A sledge from the side should help...think you'll find it goes a lot easier than you'd think.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 09-01-2012, 05:55 PM   #5
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Pry them up. Those nails are for lateral hold strength not verticle
Studs are loaded from above, the concern is them shifting horizontally.
It ain't gonna go up!
JonJon is offline   Reply With Quote
Old 09-01-2012, 08:00 PM   #6
Guest100615
Account closed per your request
I saw this recently. 3:30
Guest100615 is offline   Reply With Quote
Old 09-02-2012, 09:40 PM   #7
slo323ci
My Ride: 00 323ci
Thanks guys for clearing that up. Will try soon.
